coolant temps? - Ford Powerstroke Diesel Forum
Old 08-12-2012, 02:25 PM
coolant temps?
Got my insight hooked up checking my deltas....86 outside and cruising on the highway for around 30min at 60-70mph,no load and my coolant stood around 210-216 and oil was 210-218.The oil and coolant stood pretty close to eachother with oil being around 1-4 degrees higher..But than sometimes the coolant would rise 1-4 degrees higher than the oil...Is that normal?...At one point doing around 65-70 the coolant temp shot up to 223 with the oil around 221-224 but than the fan kicks on and brings the temps down to around 212-216..Honestly I had my truck for 5yrs now and to me it always ran hot because I would always hear the fan kick on......But now that I can check the temps I wonder what my temps will be on like a 95-100 degree day..And i'm not even pulling a trailer..........
Old 08-12-2012, 04:32 PM
That seems a little hot to me for a stock truck without towing.
I don't think it is hurting anything though since the fan brings it down.
Things you might check:
loose belt
plugged radiator fins (or something reducing the normal air flow)
extra heat from sticking turbo
sticking thermostat
Old 08-12-2012, 04:54 PM
I agree that does seem high on the coolant temp. How does the insite take readings? Does it use factory sensors or are they installed. If installed , where are they installed? If factory is used I would verify that the reading is correct. Easiest way to verify is look at all temp sensors after a cold soak and the readings should all be close to the same(within a couple degrees).
Old 08-12-2012, 05:03 PM
KING of BLING!
That does seem a little hot. I know mine was at 190* and that was high 90* weather today.
Old 08-12-2012, 06:26 PM
Thx guys..Bismic I will check all those things...How would I know if thermostat is sticking or not working?....And how do I find it?...thx
Old 08-12-2012, 06:28 PM
The thermostat is cheap, I would just replace it.
Thermostat (doesn't include the o-ring): 3C3Z-8575-AA
Thermostat Housing O-ring: 3C3Z-8255-AA
Old 08-12-2012, 06:31 PM
I totally agree.
Old 08-12-2012, 06:35 PM
Thats hot. when its 100+ degrees outside my truck runs ECT-190-192 EOT-195-200 at 70 mph, cooler at 55.
When its -20 - mid 70's ECT- 188-190 EOT 191-195.
Towing 10k+ my truck runs those temps yours does. id start by replacing the t-stat. im not sure on the condition of your cooling system but your rad could be getting plugged up. externally your rad might be full of stuff. washing it out couldn't hurt
Old 08-12-2012, 06:36 PM
Yours look perfect.I just noticed the icon I picked is named liar.
Old 08-12-2012, 07:48 PM
Is the thermostat easy to change out?...And where do I locate on the engine...thx
