Long cranking truck, hot or cold
I just finished doing studs & gaskets, injectors, fuel system, mad turbo, stand pipes, dummy plugs, icp sensor, and a new oil filter stand tube on a 2006 f250. Truck already has an updated stc. Truck fired after two 15 second cranks. I let it idle while I buttoned some things up (reassemble interior, change coolant filter, etc). Truck ran really strong. Then I shut it down to do some exhaust work and it still took 8-10 seconds to fire back up. After idling for 20 minutes could I still have air in the system? Could the new filter stand tube be letting the oil drain back (oem filter and cap)? What Icp and Ipr PIDS should I be monitoring with my CTS?
I believe most guys say you need to get it out on the road and run it. Check this......Write Up: Monitoring the 6.0L PSD.
Sent from my phone that somebody didn't help me get. |
Yeah. You definately need to drive it after that much work. Theere will be alot of air in the system
After I did my hg, studs, ect... it cranked long for about the first 50-75 miles. After that she fired right up normally again
drive her some and repost if there is still problems i vote air in system.
I think you'll be good man |
Yes drive it hard, could still have air.
I had the same problem with mine after replacing an injector. I drove her wot up a good hill a couple of times and after it started up fine
I think you should drive her hard.
