Engine problem - Ford Powerstroke Diesel Forum
Old 08-12-2012, 11:48 AM
Send a message via Skype™ to Bluedemon6.0
Engine problem
Here we go again. Here I am trying to get my truck on the road and this what happens. First I would like to say that before all of this my truck ran fine, I just had a delta of 25*. That is it. Saying all of this I replaced my oil cooler, blue spring update, egr delete, cleaned turbo, oe hg's, arp studs, head work ie (valve guides replaced and seals, milled), new standpipe, dummy plugs, installed exhaust manifold gasket, 6.4 Bangos installed, new radiator. I installed everything tried to crank but I got 4 on the icp reading it was no building pressure. So I pulled the oil filter to see if there was oil in the housing, not thinking about it at the time the oil looked milky. I just wanted to get the truck kranked. I posted on the org. and somebody said I might have installed my standpipe in wrong. So I pulled off the fuel rail on the passenger side and I did install the standpipe in wrong. So I swapped them around and she started building pressure immediately. Before long she was running I pulled the codes to see if there were any and there was none. So I decided to take her down the road to see if she would loosen up. I drove about 1/4 of. Mile and she started to knock, I mean like somebody playing the bass drum. So I limped her home, still no engine light. I pulled the codes and got a p0284 so I pulled off the driver side valve cover and there was milky oil all over the inside of the cover. I pulled the fuel rail and inspected the rockers and push rods. The only thing I found was the injector was not torqued it was loose. That is where I am at now. What do you guys think? I have good oil pressure and my eot and ect are good. Do y'all think a loose injector could cause a knock like that or maybe my exhaust manifold is leaking? I need some thoughts. Right now I plan on retorqeing the injectors and changing the oil. Oh and when I drained the coolant I had no oil in my coolant. Thanks.
Old 08-12-2012, 11:51 AM
Another thing is we have been getting a lot of rain is it possible I had enough moisture in the block to cause the milky oil. It sat up for almost 2 months. What do you guys think?
Old 08-12-2012, 12:21 PM
How much coolant is missing? How much higher is the level on the oil stick?
Old 08-12-2012, 01:09 PM
No coolant missing. All the way to the max on the oil dip stick. None on the metal part of the stick.
Old 08-12-2012, 01:38 PM
The more I think about it. The more I remember. I also remember opening the hood and smoke. That is why I think exhaust manifold gasket. I put them on and used the specific torque pattern. I don't know. I'm just really worried about that sound. It didn't sound like metal on metal just really deep like a bass drum.
Old 08-12-2012, 01:44 PM
Like maybe a whoopping sound from the intake?
Sent from my phone that somebody didn't help me get.
Old 08-12-2012, 01:58 PM
I don't think a whooping sound. More like a bass drum the beat would speed up with increase in rpm.
Old 08-12-2012, 03:12 PM
Did you position the crank dowel at the six-o-clock position, before you tightened your valves down.
Old 08-12-2012, 04:05 PM
Yeah I sure did. Any ideas?
Old 08-12-2012, 05:16 PM
Just trying to think of some stuff, was sounding a little like the bent pushrod symtoms, maybe not.
