Long Starting - Ford Powerstroke Diesel Forum
Old 08-09-2012, 08:19 PM
Long Starting
Ok so my truck started perfect until I went on a road trip over 1300 miles then I noticed that it takes a long time to start, this sounds like a dead battery kinda but will start up. What will cause this I have looked every wherei don't have any codes no issues when driving.....
2005 ford 6.0L power stroke fx4 crew cab
Old 08-10-2012, 04:16 AM
Is truck hot or cold when this happens
Sent from my DROID Pro using AutoGuide.Com Free App
Old 08-10-2012, 04:23 AM
sounds like you might possibly have a high pressure oil leak. When you have a leak it takes longer to build up pressure than normal.
Old 08-10-2012, 05:30 AM
Just like Big Red said. I had the same problem and ended up replacing my dummy plugs and standpipes.
Old 08-10-2012, 09:50 PM
The truck does this all the time... How much is the parts big red to fix and is it easy
Old 08-10-2012, 09:59 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Before you go tearing into that motor on a hope and a prayer and costing yourself a chit ton of money throwing parts at it get a monitor on it and monitor your ICP pressure Actual and Desired KOEC,KOER as well as IPR % Actual and desired KOEC, KOER. Take the batteries out and to the auto store and have them load tested INDIVIDUALLY. Test your alternators and also on your monitor check your FICM voltage KOEO, KOEC, KOER and find out what those voltages are. When you have all that info post it back here and then we can go from there.
Old 08-11-2012, 03:56 AM
Hey guy, I have ae scan tool id be happy to help you diagnose truck. Send me a pm.
Old 08-11-2012, 04:51 PM
Sounds like a plan I will check the ICP and let u know what it's is
Old 08-11-2012, 04:54 PM
Hello
Hello bro how are you I need to meet up ith u and see if u can scan it I went on a road trip and just noticed it takes longer to start. I was thinking its the ICP but not sure what's ur cell number talk to u soon
Sent from my DROID Pro using AutoGuide.Com Free App[/QUOTE]
Old 08-11-2012, 05:18 PM
Pm sent
