Low FICM Voltage - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-07-2012, 02:06 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
Low FICM Voltage
When i start the truck, my battery voltage sits around 11v to 12.5v and it remains this way for approx 2 or 3 minutes. Once the 2 - 3 minutes are up, the voltage rises to where it should be. Also my FICM voltage is droping down as low as 43v before the truck is warm
So now the parts i have in question are:
Batteries (replaced Jan. 2012) - Optima reds
OEM FICM
I think OEM Alternator
What would be your best solution to this issue?
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #2 of 18 Old 08-07-2012, 02:13 PM
The Silent Service
colo_dually's Avatar
Quoted: 12 Post(s)
First the batteries aren't holding the right float voltage for the FICM, if the batteries can't hold over 12v before cranking it can take a toll on the FICM. The Optima Reds don't have a good track record in these trucks.
The FICM is in need of replacement/rebuild, 43v is very low and it will take a toll on the injectors if not corrected.
As for the alternator, what's your voltage sitting at after the alternator kicks on (there is a delay after cranking to shut off the glow plug circuit)?
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 18 Old 08-07-2012, 02:19 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
as you know i ordered the FICM from BPD but i am starting to have second thoughts that that is the core of the issue. once the truck is warmed up and has run for say 5 minutes, the voltage stays at ~13.5v.
i am not sure the voltage prior to cranking. i will have those numbers in just a moment for you.
I did a basic test to check the alternator by turning on my bright lights (although they are HIDs - less power draw) and turning the A/C all the way up with the radio turned up. there was no fluctuation in the battery voltage. My thoughts that this happened because the alternator was carrying the current properly.
I am aware of the optima battery issue, i just wasnt at the time i spent an arm and leg to buy them.
post #4 of 18 Old 08-07-2012, 02:24 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
Before ranking while key is in "on" position
Battery voltage - 11.7v +/-0.1
FICM voltage - 48v
post #5 of 18 Old 08-07-2012, 02:31 PM
The Silent Service
Quoted: 12 Post(s)
Those new batteries aren't any good. I'd see if you can swing by an Autozone, or the like, and get the alternator checked. Just to be sure.
You will want to get the power issue taken care of before putting that new unit in there.
Did you get the 4 phase, or the 6 phase unit from them?
post #6 of 18 Old 08-07-2012, 02:35 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
Correct me if i am wrong, but once the truck runs for a moment, the battery voltage rises to 13.5v. Would this not indicate that the alternator is working properly?
I agree with running the test. I cant think of any negatives from testing the alternator.
I ordered the 6 phase. supposed to be here on the 10th
post #7 of 18 Old 08-07-2012, 02:41 PM
The Silent Service
Quoted: 12 Post(s)
13.5v with the alternator engaged isn't too bad, most likely its trying to overcome the lack of charge on those batteries. So I'd go with those first, and I know it sucks since you just got those Optimas.
post #8 of 18 Old 08-07-2012, 03:00 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
i will never buy another set of those piece of s*** batteries again. This is absolutely obsurd that easily one of the most expeincive batteries on the market is the biggest piece of crap. What is even more frustrating is the fact that i had to buy two of the D*** things.
Live and learn.
Anyone want to buy a set of freshly warrenteed optima red tops?
post #9 of 18 Old 08-07-2012, 07:19 PM
van-boy's Avatar
return them. they are under warranty. i got a set of 850 cca interstates and after a year and a half, they went bad. the shop charged me 48 bucks to do the test but replaced them for free not pro rated. they replaced them with 650 cca saying that the inside plates were thicker. dont know if thats bs or not, but i agreed to let them do it.
bailey
cut me some slack, its a work truck.
van-boy is offline
post #10 of 18 Old 08-07-2012, 07:32 PM Thread Starter
Chatham036's Avatar
Quoted: 135 Post(s)
If i am not mistaken, they will only exchange them while they are under warranty. If they will allow me to return them for cash so i can purchase decent batteries i will be pleased. All Advance auto carries here is optima and Autocraft.
