WOT lag at first
Can anyone tell me what would cause a 6.0 to bog down when you first stomp down on the fuel pedal. My 05 6.0 hesitates before taking off when I floor it at a dead stop and when crusing down the road. After a second or two it takes off like a rocket .
That's the standard lag of the stock turbo, it tends to spool better when you roll into the throttle vise dropping it to the floor. Has to do with the control of the vanes, from what I've gathered.
Are you just smashing the go pedal or rolling into it?
Exactly......engine has to generate exhaust flow to spool to the turbo first
Welcome to the world of turbos
It might be that the vanes, unison ring or the VGT solenoid just arent working properly. |
Yep...get used to it dude. These 6.0s need RPMs and boost to get anything done. Even with a powermax, if I put it to the floor from a stop, it takes what seems like forever for it to light up and go. And that whole time it's billowing so much black smoke you'd think it's a Cummins. I wish it had more low end grunt, but you just get used to it and adjust your driving habits accordingly. Heck I can't even chirp the tires when I put it in reverse and nail it real quick. Lots of smoke and whistling, but by the time the power hits, waaayyy to much speed for going in reverse...
If this is a cause of concern, that you want to do something about it, I recommend looking into FICM tuning.
A +40HP (PHPs - Altas40, or IDPs Moderate) or +80HP file (PHPs - Atlas80, or IDPs Exterme), would provide an improvement in low end fueling and torque, and get the stock turbo spun up sooner. |
Mine responds the same. It takes a min to get upand go. Seems to be a whole new animal when you steadily roll on the throttle though..
