Help - Ford Powerstroke Diesel Forum
post #1 of 28 Old 08-06-2012, 08:40 PM Thread Starter
Quoted: 2 Post(s)
Help
Hi,
I have a 06 6.0. Wouldn't start. Checked ficm. Was dropping voltage. Put new one in, and voltage holds. Now you can even hear the injectors clicking key on engine off. Cranked and cranked. Still no start. No smoke out of exhaust. Tried hitting it with brake cleaner and either both. No start still. Bought 2 new batteries due to the others being trash. Any suggestions
2012 F-250 6.7 Powerstroke ATS Aurora 4000 Turbo, S&B Cold Air Intake with Dry Filter, No Limit Fab EGR Blocker Plates, 5" Flo-Pro Exhaust without Muffler, EZLYNK from PPEI
current project- 2003 F-250 5.9L 24 Valve Cummins, P-Pump Conversion, HE351CW, 5R110 with stock controller, 4" turbo back exhaust, DCS tuning and hard parts
Yellow Rose Diesel, Amarillo TX
Pcfr108 is offline
post #2 of 28 Old 08-06-2012, 08:50 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You need to get some sort of monitor in this truck for anyone to be able to help. Sounds like a HPO leak but without a monitor there is no telling. Get a ScangaugeII or Edge Insight CS/CTS or if you have an iPhone/iPod touch/iPad then you can order a Dashboss setup the edge and dashboss will monitor the ICP pressure you need to know if your reaching 500 psi or not. If your hitting under 500 psi then you have a HPO leak.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 28 Old 08-12-2012, 06:44 PM Thread Starter
Quoted: 2 Post(s)
Okay. I hooked up a genesis system to it. HPOP was only producing 25-30 psi of pressure at a mAx. It was calling for 1000. Sounds like I need a HPOP wouldn't ya say?
Pcfr108 is offline
post #4 of 28 Old 08-13-2012, 06:27 PM
southend's Avatar
Google hpop leak test.
Sent from my phone that somebody didn't help me get.
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 28 Old 08-13-2012, 06:36 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Sounds like you don't have enough pressure/aren't reading correct pressure for some reason.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 28 Old 08-14-2012, 06:27 PM Thread Starter
Quoted: 2 Post(s)
This is what I found when tearing apart. It smells like old oil(the residue). Pulled the front 2 plugs and both of them had blown out o rings
ID:	41847   Click image for larger version
ID:	41848   Click image for larger version
Pcfr108 is offline
post #7 of 28 Old 08-14-2012, 06:30 PM
southend's Avatar
Pics are small, but that would cause problems.
southend is offline
post #8 of 28 Old 08-25-2012, 11:19 AM Thread Starter
Quoted: 2 Post(s)
Replaced the dummy plugs. Still no start. Gonna try the stc fitting next, any suggestions?
Pcfr108 is offline
post #9 of 28 Old 08-25-2012, 12:04 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Yeah buy a new hpop, ipr valve, stc fitting, and new stand pipes and do it all at once. Instead of ripping it apart and putting it back together and ripping it apart and putting it back together. Chasing a hpo leak is a daunting task and can get very discouraging. Whatever parts you don't use then send them back for a refund.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #10 of 28 Old 08-25-2012, 12:47 PM
southend's Avatar
It's an 06, not a big hpop problem on those trucks I thought? Did you bother trying the hpop leak test?
southend is offline
