TFT Sensor Replacement. Writeup - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-05-2012, 08:03 PM Thread Starter
2003kingranch's Avatar
A little writeup on replacing a trans fluid temps sensor in a 5R110.
If your seeing this and your trans is not actually overheating, or its jumping all over, its time
You will need
9-10 Qts of MERCONŽ LV $63
And a new ford TFT sensor $15
Get yourself a drain pan (you'll get about 9 qts out) and pull the plug(1/2" socket) let it drain for 10 min, the longer you wait the less mess your going to have.
Start taking out the pan bolts (10mm) Anytime im working on a trans with a reusable pan gasket i all ways take out every other bolt.
Pull the pan off carefully.The TFT sensor is located in the green circle
Unplug it, rotate it cc and then pull down. some fluid will come out so get out of the way!
Just the opposite for the new one. push it in and rotate it cw, and plug it back in.
Wipe off the pan gasket and surface on the trans, and put it back on. torque them to 11Ft lbs. Refill the trans fluid. (mine took right at 9 Qts)
Done!
[/URL]
[CENTER]2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #2 of 3 Old 08-05-2012, 08:06 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
Good write up, torque specs and everything. Thanks for your effort.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 3 Old 08-06-2012, 07:02 PM Thread Starter
Thanks. should be useful to someone
[/URL]
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
