more ficm ?'s - Ford Powerstroke Diesel Forum
Old 08-05-2012, 06:47 PM
more ficm ?'s
I have 58ficm in my truck, I was told by a diesel mechanic going higher with voltage will max out the injectors a little more, tuning it will max them out even more but its not smart. For example its pretty much the same as putting 100 watts into a 60 watt bulb, or unplugging a 120volt appliance and plugging it into 210 service.
Old 08-05-2012, 06:53 PM
The Silent Service
Not sure about the source, but that is simply not the case.
There are more than a few guys running high voltage FICMs, both tuned and otherwise, and haven't heard/seen anything damaging about it.
What is taking out injectors isn't the higher voltage, its folks not paying attention to their Fuel Pressures as they push the electronic tuning.
Old 08-05-2012, 06:57 PM
I know I'm probably the only person here with a non tuned ficm! I got the 58v as a slight upgrade but when I got it the seller said ficm tuning was all hype so I opted out.
This might be a dumb question but is the actual temperature of the ficm hotter when tuned?
Old 08-05-2012, 07:00 PM
The Silent Service
You're not the only one. I'm still running the un-modified stock FICM unit.
There is a curtain increase to temps, but I doubt its anything worth mentioning.
Do you know which FICM tune you want to install with that MTW Stage 2 under the hood?
(If you don't mind, shoot me a PM with your opinion and thoughts about that turbo. I'd like to hear what you think about it.)
