Fuel pressure low after blue spring update. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-16-2012, 07:30 PM Thread Starter
at0075's Avatar
Got my truck put back together after egr delete and oil cooler. Installed the pressure regulator blue spring kit. When it fired up my fuel pressure was sitting at 70 psi. I ran it all Sunday afternoon and it hovered around 70 which I was happy about. Got up this morning for work and fired it up and now it's 50 psi. It's been 50 give or take a couple psi all day? Any ideas?
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #2 of 6 Old 07-17-2012, 05:37 AM
Quoted: 58 Post(s)
It sounds like your HFCM might be on it's way out. What was your fuel pressure before the Blue Spring upgrade? When were fuel filters last changed?
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 6 Old 07-17-2012, 01:57 PM Thread Starter
at0075's Avatar
Fuel pressure was about 60 or so and my fuel filters probably wouldn't hurt to be changed. I mean it's pegged at 50 and doesn't fluctuate much at wot
at0075 is offline
post #4 of 6 Old 07-17-2012, 07:44 PM
Quoted: 58 Post(s)
Should be higher with the blue spring. Sounds like your HFCM is getting week...
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #5 of 6 Old 07-17-2012, 07:54 PM Thread Starter
at0075's Avatar
Well that's great. Just spent almost 2 grand between fixing the air and deleting the egr/ oil cooler rebuild lol. Might as well throw it in too lol. How much does the factory hfcm run? Would it be reasonable to just upgrade fuel system or is that a big leap money wise?
at0075 is offline
post #6 of 6 Old 07-18-2012, 05:44 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Until you start to see it drop below 40psi under WOT, I wouldn't worry about it. Right now, you say it's maintaining 50psi even at WOT, which is still fine for your injectors. I think the HFCM is right around $500, but you might be able to find a used one for around $100 from folks that have gone to an aftermarket fuel setup. Unless you are going for all out speed, the stock fuel system is probably adequate.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
