Oil cooler change - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-16-2012, 11:46 AM Thread Starter
Stumppy's Avatar
Oil cooler change
Getting ready to do some work on my truck. Deltas are about 20 apart. So I am deleting the egr cooler replacing the oil cooler, blue spring, banjo bolt, coolant filter. I plan on flushing the system first and replacing the coolant with elc. When Im all done my question is will I have to replace the oil cooler again after I do all this? I also just bought a sct and tunes from vivian. Anything else I will need while I have it torn down this far? I will post pics of my progress as I tear it down and replace all this. Never worked on a diesel before so I plan on giving myself few days to do it all and hopefully it all comes out right..
Stumppy is offline
post #2 of 3 Old 07-16-2012, 02:16 PM
tylerb05's Avatar
Pretty sure you keep the oil cooler that's been on the ( not the after market one) and flush it and run restore and restore + and also distilled water after . There is a exact step by step somewhere on here. After you do all these flushes then replace the oil cooler cause usually the oil cooler will plug up after a chemical flush so I am told.. But yes 20* is def a time for some changes.. Asap
Tyler.
03 f250 king ranch 4x4 6.0, 2.5 level with bilistein 5100s,04 KR Rims with Toyo open country 33/12.5/18s , GONE LOONEY , bully dog cold air intake, mbrp 4inch turbo back exhaust 5inch tip, edge insight cts w/ egt probe, sinister coolant filter,Updated hcfm plug Blue Spring, Rotella T6,10k headlights and fogs, EGR Gone, ELC
Upcoming:
W/M injection
Injectors
tylerb05 is offline
post #3 of 3 Old 07-16-2012, 03:19 PM Thread Starter
Stumppy's Avatar
I wouldn't change it till after I flush it then replace with a OEM cooler.
Sent from my DROID RAZR using AutoGuide.Com Free App
2004 CC SB 6.0
4 Inch Turbo back Exhaust
S&B Intake
Sct with Vivians looney wild tune.
Egr Delete
Arp Head studs and oem gaskets.
Stumppy is offline
