Scott's oil filter - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 11 Old 07-14-2012, 10:40 PM Thread Starter
Scott's oil filter
Anyone ever use these its a lifetime oil filter.
devster55 is offline
post #2 of 11 Old 07-14-2012, 11:19 PM
mazsecond's Avatar
Feedback Score: 4 reviews
NO, NO, NO, NO, NO!!!!
Don't do it! I don't care what the package says but it for sure does not apply to the 6.0. ONLY use the MOTORCRAFT OR RACOR filters for these trucks. Don't use Wicks, Napa, or any walmart special. The Ford/Racor filter is patented to a very specific tolerance that no other filter meets, which can cause oil to be partially or in extreme cases completely bypassed and cause some serious damage to your engine. Just read some posts on here about oil filters and you will quickly learn why to only use the Ford filter!
I'm sure others will agree...
mazsecond is offline
post #3 of 11 Old 07-14-2012, 11:34 PM Thread Starter
Well I've been using motorcraft filters just wondering.
post #4 of 11 Old 07-15-2012, 04:52 AM
southend's Avatar
I agree.........no such thing.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #5 of 11 Old 07-15-2012, 10:22 AM
The Fram filter is the same as the Racor/Ford.
From what I understand the Fram is just a rebranded Racor. Fram decided the liability to use a non patented filter in these engines was not worth it so the made a deal with Racor to supply them.
Take a Fram & Motorcraft filter out of the box at Wally Workd and they are identical right down to the patent numbers on top. The only difference is the Fram is one dollar cheaper than the Motorcraft.
SHOOTER22250 is offline
post #6 of 11 Old 07-20-2012, 05:09 PM Thread Starter
I'm just tired of paying 30 bucks per filter so that's why I was looking into that still open to sugestions.
post #7 of 11 Old 07-20-2012, 07:30 PM
Quoted: 27 Post(s)
Then pay less (around $18) at walmart, or Dieselfiltersonline.com, or get them from International. Frams are OEMs also as Shooter said ..... you can get them at a bunch of places.
http://www.dieselfiltersonline.com/F...r-Fl-2016.aspx
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 11 Old 07-20-2012, 09:12 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
I just got one today motorcraft at advance auto parts for $20.
huck2080 likes this.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 11 Old 07-20-2012, 09:36 PM
War is the answer!
WarChild's Avatar
Quoted: 24 Post(s)
It would be a bad idea to stray from motorcraft/racor filters.
White 04 F350 Lariat SRW/CC/LB/FX4 227,XXX+
Studs/BPD58V FICM Atlas40/BPD oil cooler/waterpump/7.3 fan
Edge insight CTS EGT/Turbo timer/FP SCT with ? Tune
Powermax w/KC billet wheel Warren 175/30%
5-8" MBRP Off Road Turbo Back/harpoon
2" Leveling/33' BFGATKO
ELC/PMM Coolant filter
aFe Stage2/EGR Delete
(Always Faithful) is the motto of the Corps. That Marines have lived up to this motto is proved by the fact that there has never been a mutiny among U.S. Marines.
WarChild is offline
post #10 of 11 Old 09-25-2013, 02:26 PM
So last night I was in Wally World and stopped by the oil filter section for a side by side comparison. They had three filters that would fit the 6.0 liter.
  • Fram CH9549 Standard filter offered by Fram
  • Fram TG9549 Upgraded filter offered by Fram
  • Motorcraft FL-2016 / Ford 3C3Z-6731-AB OEM filter
I compared Motorcraft to the ToughGuard, and they were identical. Same height, same end plates, identical numbers stamped on the endplates, except Fram had added their part number to the ToughGuard filter. There was no notible difference in the two filters.
Then I compared the Standard Fram CH9549 to the ToughGuard. There is a clear difference. The endcaps are different. The height isn't the same. And the standard Fram has no patent numbers on it anywhere. In the past, I've found genuine Racor filter in CH9549 boxes, clearly that is no longer the case.
txgp17 is offline
