just bought my first 6.0 - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-14-2012, 06:14 PM Thread Starter
Dixienormous's Avatar
I've had a 7.3 for many years and I sold it then I found a sweet deal on a 05 6.0 fully loaded ,what do I do to keep it going I don't want to chip it or any performance work yet just want to make sure it keeps on going
It does have some problems like the electronic 4x4 doesn't work some death wobble (it looks like a loose tie rod end) when I lay the shifter to rest in reverse gear the cab lights come on and then it says rear left door ajar
And there is white pasty stuff on the water lines
Thanks Matt
2005 F-250 FX4
2001 F-550 4x4 Western hauler
2004 F-250 cummins 2.5ton Rockwells on 53s
1965 Mustang GT 4 speed to loader
1969 pink mustang convertible GT M-code 4 speed toploaer
06 dodge ram 2500 TRX-4 straight piped and intake
IN GOD WE TRUST
Dixienormous is offline
post #2 of 19 Old 07-14-2012, 06:17 PM
xu67585's Avatar
Quoted: 5 Post(s)
Garage
I hope you got a GREAT price. Is the white stuff by the degas bottle?
2005 F250 SC SB
ARP Studs, RCD Egr Delete, Homemade Coolant Filter, Stand Pipes And Plugs, Banjo Fittings, Blue Spring,
STC Upgrade, FleetGuard ELC, Cat Delete, Zoodad Mod, CCV
xu67585 is offline
post #3 of 19 Old 07-14-2012, 06:57 PM Thread Starter
Yea kinda by the clamps what is that stuff and I think alright at 7000 its got every option possible
2005 F-250 FX4
IN GOD WE TRUST
post #4 of 19 Old 07-14-2012, 08:28 PM
Adamv7010's Avatar
Hope you're ready to spend 4-5g
The white stuff is dried coolant that's 'puked' or forced out of the Degas bottle under wot when pressure exceeds 16lbs. Try the updated Degas bottle cap first then do studs gasket oil and egr coolers
Adamv7010 is offline
post #5 of 19 Old 07-14-2012, 08:38 PM Thread Starter
Really is it that bad I drove it 4 hours home didn't go over half on the gauge
2005 F-250 FX4
IN GOD WE TRUST
post #6 of 19 Old 07-14-2012, 08:40 PM
Adamv7010's Avatar
It can and most likely will be
post #7 of 19 Old 07-14-2012, 08:46 PM Thread Starter
So the head gaskets are blown ? It seems like I can tighten the hose clamps wash up the white stuff and be fine
Is there a test to do before I spend all this money ?
2005 F-250 FX4
IN GOD WE TRUST
post #8 of 19 Old 07-14-2012, 08:47 PM
I wouldn't panic just yet, the degas bottle could be overfilled or the cap is no good.
You may want to look into getting a monitor.
lethald is offline
post #9 of 19 Old 07-14-2012, 08:50 PM
Adamv7010's Avatar
Never said that. Check out Colo_dually's posts. He's pretty accurate.
I recently replaced my Degas bottle cap and it stopped my puking
post #10 of 19 Old 07-14-2012, 09:02 PM
I agree.
lethald is offline
