WOW!!! Archoil 9100
I changed my oil this morning w/ Amsoil 5w 40 and some Archoil. All I can say is wow. It actually dropped my temps 5 deg. It is 5 deg hotter ambient than yesterday doing the same thing and I am running cooler. It also made it soooo much quieter. I have run RevX in the past and it does even come close to Archoil. Just letting everyone know my opinion of it.
Sent from my DROID RAZR using AutoGuide.com App |
Archoil? Never heard of it. What is it, aditive for fuel?
They have a few different products, both for fuel and oil treatments.
Archoil, nano lubrication, reduce friction, reduce wear, lubricating greases, reduce energy cost, extend equipment life, latest in nano lubrication, lube,science,solutions,fuel,gas,diesel,,friction modifier, catalyst, combustion, motorsilk, lubrisilk I have used: AR2300 (cleaner, engine temp seamed to have dropped a couple degrees on the oil side, EOT. Oil got dirty very quick) AR6200 fuel treatment (can't say what it has done, repaired FICM at the same time, so tough to say the additive added any MPGs) AR9300 ( higher level of AR9100 and supposed to last more than 50,000 miles before another treatment. So, stick around for a few years and I will report my findings! I will be sending in a sample for testing on next oil change)I run Rotella T-6. I wasn't having any issues, well except the FICM, that warranted doing these additives, just thought I would give them a try. Also, a very long thread: http://www.thedieselgarage.com/forum...d.php?t=112382 |
I put the 9100 in a few Weeks ago a she doesn't run rough in the morning any more, also quieted the engine down at all temps and just "feels" smoother. It did take a couple days to notice a difference.
Oh yea, I'm running T6. Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App |
Where did you buy your archoil 9100?
I have heard about this. Anyone have the active ingreadents of the product?
We have had only good results with AR9100 & AR6200
Only positive reports and no negative. Those that were using Rev-X and triedAR9100 have switched to AR9100. |
What's the ratio? Does I replace a quart of oil with the archoil when I do an oil change?
AR9100 is 16oz to 15 gal oil
This will give you ratios and data Click here - John F. Jensen: 1 - Archoil Fuel & Oil Additives plus Others |
I just switched to Amsoil last week. I'm happy with it so far!! Nice and quiet. Never have used the Archoil though...
