2 new alternators Still not charging
I have an 03 that isnt charging. I replaced the alternator with a new one twice today (napa) with the same result. I am positive its not the alternator although my local napa is a small one and doesnt have a way to test the alternator itself other than to swap it out with another.
I am hoping there is something thats common other than the alternator which you guys can direct me to Thanks |
Sure the batteries are good?
How many amps does your tester draw? Many (most) home testers are not capable of fully testing the batteries (and they need to be tested individually as well). I have a tester too, but I realize that while it can be a positive indication of a bad battery, it is not necessarily a positive indication of a good one (hope that makes sense).
You need to test the electrolytes in your batteries with a refractometer. load testing a battery is only a partial test of a battery. ive seen this countless times while load testing a battery it shows up good but checking the battery fluids they show up bad.
And ive seen your exact symptoms with no charging issue. batterys load test good fluid tests bad install new batteries problems gone.
Inspect all the cables. Make sure there aren't any brakes or corrosion buildup but I too am going with bad batteries.
Any codes being thrown?
Nope no codes. I am going to head into the next town over and get both alternators i have and both batteries tested. Will let you guys know when i know. |
I had the same issue with my alternator. Ended up being a bad battery warning light on the dash. Weird how a little light will keep your alternator from charging
Sent from my PG86100 using AutoGuide.Com Free App |
