exhaust sound after startup - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-12-2012, 11:47 AM Thread Starter
ParkCity.PSD's Avatar
A few seconds after I fire the engine up, there is a weird change in the exhaust sound for a few seconds. Almost like a valve is opening or something and then closes again?? I'll try to take a video if I can...I'm trying to figure out how to describe the sound...
06 F350 Lariat
Edge Insight CS
Blue Spring Update, EGR Delete, STC update, Stand Pipes and Dummy Plugs, Turbo feed and drain tube update, Sinister coolant filter, New stock oil cooler, Zerex ELC, RiffRaff Boots, Isspro Fuel PSI, DC Alternator, ARP Studs, Heads from Jared, OEM Head Gaskets, Yukon Dura-Grip Posi
Warren 155cc/stock injectors
SCT with tunes from Vivian
Western 8-1/2ft Pro Plow with UltraMount
Hansen Front Mount Snow Blower
ParkCity.PSD is offline
post #2 of 4 Old 07-12-2012, 11:59 AM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
I think what you are hearing is the vanes cycling in the turbocharger?
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #3 of 4 Old 07-12-2012, 12:50 PM
Cuzmail's Avatar
Ha Ha Ha - I am laughing with you and not at you.
I had the same thought on day one with the truck. It is the VVT.
'05 F250 KR CC SWB
Mini Maxx
4" SS turbo back
AFE Stage II
EGR bypassed
Ravelco
Viper 5901
Train horns - of course !
Tool box, interior lights, & metal bed cover combo
'10 Tailgate with step
'08 Tail lights
'11 Rear bumper
Classic quote by Snake "Both of you should sell your trucks and buy imports with lots of stickers, big fart can mufflers, and a rear wing as tall as you can find. You'll fit in well with that crowd."
Cuzmail is offline
post #4 of 4 Old 07-12-2012, 01:05 PM Thread Starter
Thanks...it's just weird I hadn't noticed it before.
06 F350 Lariat
Edge Insight CS
