Y pipe wont seal to turbo - Ford Powerstroke Diesel Forum
Old 07-12-2012, 04:22 AM
hey guys i did an egr delete and now my Y pipe wont seal to the turbo we've tried to clamps and many readjustments but it wont seal. what do i do?
Old 07-12-2012, 05:10 AM
just keep working on it, sometimes its a real pain in the A$$ !
Old 07-12-2012, 05:19 AM
Unapologetically American
Feedback Score: 4 reviews
This ^^^^^
We had a hell of a time with my buddies 04, both times we had to pull the turbo. Just know that you can't use the V-clamp to 'pull' the flanges together. They have to be together before the clamp goes on.
Old 07-12-2012, 05:37 AM
Slacker
Originally Posted by 2006PSDSD View Post
This ^^^^^
Great advice from these two guys. I know that it's easier said than done, but keep at it. It WILL eventually go back together without leaking. And when it does... Best of luck, buddy.
Old 07-12-2012, 06:04 AM
thanks guys it a real pain and i have no patience
Old 07-12-2012, 06:23 AM
i also am short on patience, so it is times like these that "teach" me to have more patience!
Old 07-12-2012, 06:47 AM
it wouldnt be so bad if the truck hasnt been down 2 weeks with the egr cooler, front brakes, wheel bearings, and a few other things pluse once the turbo came out the were shims and nuts laying in anr around the motor that didnt even belong in the truck.
Old 07-12-2012, 07:31 AM
There's that raised ridge on the Y-pipe. I absolutely HAS to seat inside the turbo before the clamps go on. As others have said, the clamps will not pull it into place.
Mine was real close, but not seated. I used a broomstick to get force right where I wanted it and it popped right into the socked in the turbo. Like I said it was real close, but just wast right. It did not take a lot of force; it was more about getting a little push on the Y pipe at the right location.
There's always the approach of loosening the Y at the exhaust manifolds and starting at the turbo end & working down.
Old 07-12-2012, 07:39 AM
Put a ratchet tie down around it and go over the passenger fender (with a towel between fender and strap) and down to your wheel spoke or somewhere on the frame in the fenderwell. It will pull in by ratcheting on it a little.
I had the same problem after a turbo cleaning. A fellow member clued me in on this and it worked like a champ.
Good luck!
Sent from my SAMSUNG-SGH-I717 using AutoGuide.Com Free App
Old 07-12-2012, 09:22 AM
thanks guys i willl be trying all this friday when i get back to it i love this site its been so much help in the short time i've been on it
