EGT Temps? - Ford Powerstroke Diesel Forum
Old 07-11-2012, 04:17 PM
EGT Temps?
So I installed a SCT Livewire with EGT readout and drilled and tapped my drivers side manifold. The only thing I'm wondering is it seems everyone is getting 1000* + when laying into the accelerator. Im only seeing 600's on occasion after running her hard. Im running the Looney tune from Vivian. I also noticed it seems to run hotter when in stock tune?
Old 07-11-2012, 04:34 PM
The Silent Service
Where is your EGT probe mounted?
Old 07-11-2012, 04:40 PM
Drivers side manifold at the back of the manifold. Used the location everyone seems to use.
Old 07-11-2012, 04:41 PM
The Silent Service
Interesting, did you modify the cable at all during installation.
My only other guess, is maybe you have a bad probe.
Old 07-11-2012, 04:44 PM
No mods at all. The only thing I can think is maybe i didn't slide the probe far enough through the compression fitting?
Old 07-11-2012, 04:56 PM
How do the temps read before starting? Does it match EOT, ECT, etc?
Any chance it is reading C instead of F?
Old 07-11-2012, 05:04 PM
I'm also running a livewire and looney tune. Mine never matches EOT or ECT on startup. It always starts out on 32 degrees even if it's 100 outside. Otherwise it seems normal. I easily see 12-1300 on hard accel until I back out.
Old 07-11-2012, 05:07 PM
The Silent Service
Check the probe's location first, then check if there is a setting you've missed on your SCT Livewire.
Old 07-11-2012, 05:57 PM
Thanks for the advice guys. Ill check the settings and see if sliding the probe in further makes a difference?
