Unplug EGR if cooler leaking? E-350 - Ford Powerstroke Diesel Forum
Old 07-11-2012, 10:54 AM
So I'm picking up an E-350 6.0L pretty cheap. Reason is she's blowing white smoke/steam for about 5 mins on start up then it clears up. I'm hoping this is the EGR cooler... well not hoping but you know. If this is the EGR cooler since I plan to drive it home 40 miles (60km) does it makes sense to un-plug the EGR valve to keep it closed and avoid sucking in coolant into the intake?
Or does my problem sound like something other than the EGR and should I just tow it and avoid the risk of more damage?
I plan to do an EGR delete and replace the oil cooler, clean the turbo (I have VW's so I know all about stuck turbo vanes).
Hopefully the head gasket isn't shot as I hear you then have to pull the van body?
Pretty excited though... this will be a low use rig... for hauling poultry to slaughter, jeep to the trails and any random stuff I want to haul that's too heavy/big to fit in a VW Jetta haha
Kristian
Old 07-11-2012, 11:01 AM
Pull it the 40 miles.
Old 07-11-2012, 12:33 PM
could just be a dirty egr valve. Trying pulling it an cleaning it.
Plus when you pull it you can see if its wet. Which would point you to a blown cooler.
Old 07-11-2012, 12:56 PM
Pull it as in tow it?
Old 07-11-2012, 01:22 PM
Yea, you should get it towed.
Old 07-11-2012, 04:08 PM
The Silent Service
Have it towed before it hydrolocks.
Just because the EGR valve doesn't open electronically, doesn't mean that boost levels (exhaust pressue) won't push it open.
Old 07-11-2012, 04:39 PM
Ah I see what you mean. I'll tow her home for some diagnosis then
Old 07-18-2012, 05:25 PM
We I got it home. turns out it is throwing a P0299 code which I believe is turbo underboost?
Anyway the batteries were low from sitting so I've got it on the trickle charger. Seems the EGR cooler and oil cooler are fine!
She's a bit rusty but I'll clean it up and paint it
