About to feed the beast.
Well as the title says I'm about to feed the beast all the parts she has been wanting/ needing. I have blown head gaskets and have to rip it down so if I have to do it I'm going to do it right. Below will be a list of parts/mods I will be doing to the truck but before you comment on what else should be done please read the mods list to see what's already done to the truck and help me figure out what else I may "need" lol or other specialty tools I will need to get the job done as well. (if the CFO aka the wife sees that I'm dead lol) or parts that I may have forgotten to do the job correctly. I only wanna do this once so doing it right the first time is crucial. Thanks for the help in advance.
Truck details: 2005 F250 FTX ALL-TERRAIN 6.0l* SCT - RCD custom tuned, Sinister EGR Delete, New OEM Oil Cooler, New Intake Gaskets, New HPOP, Updated STC fitting/dummy plugs/stand pipes, New IPR Valve, Rebuilt Turbo, Dfuzer Coolant Filtration Kit, Cat EC-1 Coolant, Banks Ram-Air Intake, Quad Pillar Gauge Pod with 100psi FP, 300*f EOT, 2400*f Pyro, 60psi Boost, 4" DP to 5" cat and muffler MIA exhaust, Optima 6-pack Batteries, 6" Pro Comp Suspension Lift, 20" Eagle Alloy Rims with 35" Nitto Terra Grapplers. To do list: Arp head studs* OEM head gasket set Updated stand pipes* Updated turbo oil feed and drain tubes Ccv mod Harpoon mod Upfitter switches Ficm tuner Power steering pump Oil cooler Vc-9 flush Fleetgard restore Cat ec-1 concentrate 4 gals Oil filter* Billet oil filter cap Fuel filters Head stud torque adapter tool Torque wrenches* Torx t-27 bit Fan clutch removal tool Trans oil cooler line quick removal tool Arp stud lube* Injector o-rings* Oil Exhaust manifold gaskets* Hardened valve seats* Water/meth injection kit* Cac boots* Aluminum ic piping* Edge insight cts Fuel pressure regulator spring update High flow banjo bolts* TSD super panty dropper tune Vivian's looney wild tune Custom built traction bars front and rear Last edited by Tuscany; 07-11-2012 at 03:17 PM. |
No one? Guess I'm not missing anything then?
To the TOP.
You have SOO many items listed that i feel too lazy to read
![]() It seems like you got everything bud! Good luck on the build |
Just an FYI,
Its not the SRL Super Panty Dropper.. The panty droppers are from Chris at TSD. |
Edit; I fixed that in the OP. |
