Safe sustained boost numbers - Ford Powerstroke Diesel Forum
Old 07-10-2012, 06:36 PM
What kind of boost numbers are safe for non-studded trucks? The last trip out with the toy-hauler using the 8K tow from Matt, my boost #s would spike to 29psi and stay around 20psi cruising. Is this normal or BAD? I emailed Matt and he just asked what the #s were stock, but didn't make a big deal about it. I don't know because I haven't towed stock yet. If I return to stock, can the SCT turn off the egr? Just need to be as safe as possible (I know tuned is not safe as possible) so my wife doesn't shoot me if I lift the heads.
Old 07-11-2012, 03:24 AM
Nobody tows with a 6.0?
Old 07-11-2012, 03:52 AM
I just got mine and have not towed with it yet. I have only run SRL and average 5-10psi cruising. I've been meaning to test out the tow tune. What kind of mileage do you see with it and how often do you run it?
Old 07-11-2012, 05:13 AM
War is the answer!
28-29 is just fine. I am on original gaskets and headbolts with my 04 on 181,XXX+ miles.
Old 07-11-2012, 02:31 PM
Thanks for the answer.
