Like I stated I let my master cylinder run dry when changing calipers. I added a quart and as I was bleeding added another quart. Still no brakes. I'm not getting any more air. Will the gravity method work or do I gotta pay someone to bleed them. If so what will that cost ? Thanks guys
I have never had luck with gravity bleeding since the master is higher than the master cy lwith lots of flat areas and air traps in between
.. I always power bleed starting with the furthest caliper from the master |
So do I need a special tool to do that , I've only ever bled the old fashion way
i always use speed bleed fittings because I have no friends
and All my local auto parts stores sell them otherwise I use a mighty vac tool to suck the fluid to the furthest bleeder and then move to the closer ones
