Heat/Smoke
First off I have to start by saying Love my truck...that's not said enough on here!
I am curious about something I've noticed over the last week here in PA...I have noticed it doesn't take much for it to smoke when getting into the throttle even just a little bit. Last week it was consistently in the upper 90's with high humidity (much warmer than normal for Pittsburgh). I noticed times when I normally don't blow any smoke, I would pour out a bit. I try to avoid it as much as possible but didn't know if there was a reason for this to pop up. Now it cooled off a little and I'm back to normal. Thanks! |
Any ideas out there?!
Sent from my iPhone using Autoguide |
running richer....air is less dense since it is so hot out...not as good as combustion as when its cooler... And im sure you have your AC on which is dragging it down a bit also!
You should be fine! |
Yeah a/c ran a lot those days! Thanks man.
