Another plugged oil cooler FML... - Ford Powerstroke Diesel Forum
Old 07-10-2012, 06:27 AM
Deltas have been increasing gradually since I changed my cooler (didn't flush it first, noob mistake) I was towing 12000LBS on a tongue hitch, mild amount of hills in the area. Coolant ended up hitting 215 and the scary part is EOT hit 238 when climbing hills.
Now I don't feel like swapping another oil cooler out, so in regards to people who have done the BP external oil cooler kit. How was the installation compared to a regular oil cooler time frame wise.
Old 07-10-2012, 06:31 AM
DBM DBM is offline
check your delta on flat highway and at 60 mph unloaded first... that delta may not be too high for a load in hills...
Old 07-10-2012, 06:35 AM
Slacker
Feedback Score: 4 reviews
. The "delta" test is specifically for unloaded trucks.
Hills here are probably smaller then your thinking lol. Delta un-loaded is 14ish, so it's out of spec IMO. Aren't these trucks set to defuel around 245* EOT.
Old 07-10-2012, 06:39 AM
Slacker
It will defuel at approximately 253*F EOT. The PCM measures it in Celsius.
Old 07-10-2012, 06:43 AM
Noted thanks! Hows your BPD oil cooler set up?
Old 07-10-2012, 06:49 AM
Slacker
Works great and since it has gone in, I haven't had a single issue with clogging oil coolers or blown EGR coolers. Since I tow a heavy toy hauler here in the desert of Arizona, I was going through them about once a summer. Most of my buddy's have had similar experiences towing their toy haulers and blowing oil/EGR coolers. It's a very comforting feeling knowing that I don't have to deal with those issues any more.
Old 07-10-2012, 11:47 AM
Can't say enough good things about my BPD oil cooler.
Old 07-10-2012, 07:20 PM
Looks like I'll be purchasing one of these.
