First 5K mile service coming up. What to expect?
Looks like I'll be going in soon for the first 5k mile service. Any advice/guidance on what to expect from the dealer?
I know these PSDs are a little more picky with regards to service, but other than your normal oil change, is there anything else I should have replaced? This will be my first service since buying the truck. It had ~35K on it when I bought it and I'm about 600 miles out from the recommended 5k services. I usually do all of my own work/services, but being new to the PSD engine, I figured I'd let the dealer handle the first service or two. So, how often do you guys have your rigs serviced? Mine mainly sees highway/city driving duty with very minimal towing. What else should I put on the "list"? Air filter, fuel filter, trans fluid, etc? Also, what about re-flashing? That seems to be a pretty hot topic for a lot of folks on here. Is this something that would need to be done to a low mileage 05? I'm guessing most of these should have been addressed/replaced when the truck was traded in, but I have no way of being sure. I do know the coolant reservoir issue (min line is actually max) has been addressed since I noticed the sticker this weekend. Any guidance you folks could give would be greatly appreciated! Thanks! |
Oil changes are expensive at a dealer and way to easy not to do yourself. Just get 15 quarts of your favorite diesel oil, a 15 quart drain pan and a filter. Takes 10 minutes!! The dealer charges around 120 bucks and you can do it yourself for prolly 55-60 bucks.
I would do a tranny flush at the dealer if your past 35k. Air filter, just inspect it and change that yerself too - tricky the first time but after you get it done once, it aint hard the next time.Other than that, you should be good... just do a general inspection underneath but you prolly won't find anything. Tranny service is around 130 i think but it may vary from dealer to dealer. |
RE: the oil change - what brands do most folks run around here? Best place to buy oil from? Also, any tips/tricks/guidance to getting the job done right on the PSD? Same for oil and air filters - what's the usual brand? Best place to buy? I'll look into the trans flush a little closer. Might can find out if they've already done that prior to selling the truck. Thanks in advance!! |
Also, do you have the maintenance guide in your owners manual? I am trying to make sure I follow that almost to a T. Most people just say to use the motorcraft filters and whichever oil you prefer. If you change it often enough, it shouldn't really matter what brand of oil you use.
some people use these sites for their filter purchases.. FleetFilter.com powerstrokepartsusa.com - Product Details Definately check with the dealership you bought your truck from -- they should be able to tell you what work they performed, if any, on the truck before you purchased it. |
Also plan on checking on that maintainence guide and past maintainence history from the dealer. Keep the advice coming! Thanks! |
no prob bud... also found this -- spells out the basic oil change on a 7.3 -- but is basically the same -- he also gives some good info in the vid I think..
[H]acked By FeriouS - How to change your oil on a 7.3L Powerstroke Diesel. Definately check on the service history if you can -- I get my oil changed at the dealer only because I pay $75 thanks to my father-in-law working there -- otherwise I'd be doing it myself |
Oil - Rotella T 5w40 i think is what I have been running, i used the Rotella synthetic once and wasn't too impressed. I am going with Amsoil next and gonna try to get 15k miles out of one oil change with it. They claim 25k miles with there 25k mile filter but i don't know if i can go that long.
Oil change is simple, drain it, change the filter located smack dab in the center of the engine compartment on top, and fill er back up. You'll need a 36mm socket to remove the black cap on the filter bowl - its the larger of the two black caps you will see, the small one is your secondary fuel filter. Which speaking of filters, those should be replace for sure is they havne't been recently. Those are easy to replace also. One on top and one under the drivers seat on the fraimrail...also a 36mm socket and you have to have a socket to get to that one especially if its 4x4 with that extra driveline up front. Those filters will run you about 65 bucks for the two at any auto parts house. I get oil and oil filter at Wal-Mart - they also carry the air filter. What else.... if i missed anything someone will catch it. You can do all this in a couple hours with no problem and save a few hundred buck. |
Clay, Brant, thanks again for the help. I'll check out the link and see if I can't run down some oil and filters in the next few days.
Sounds like something I could easily take care of myself. And saving money is never a bad thing! |
especially with "The Money Pit" Camaro you have
![]() hehe, its okay - I have an 82 Trans Am that will be a money pit sooon enough
Haha...man, that car has sucked up so much of my money in the past year and a half it's not even funny. Bad thing is, it's all my own fault. Never can leave anything alone or stock. Went through a couple different heads and cam setups, two different exhaust systems, two different intakes, two different sets of headers...you name it, I've just about changed it on that car... Guess I'll never learn....:burnout |
