A helpful note when doing head gaskets cab on - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-08-2012, 06:08 PM Thread Starter
Some may know this and done this but for those that haven't well this is a added step but helps when torquing the heads down. Just remove the spacer between the block and the frame motor mount. This allows you to raise or lower the motor enough to get a even a large heavy duty torque wrench on. there are 3-4 bolts on the block and 4 bolts on the motor mount side. For best results use a 13mm ratcheting closed end wrench. also when reinstalling install the 4 bolts in the frame motor mount side and then the block side bolts. I did this and I didn't have to do anything to the heater or the driver side rear bolt area. Just use a jack and a piece of wood (treated 2/6 for me) on the driver side bell housing area on the block. just put the jack part way up and then cut the wood to fit that you can raise or lower it depending what side your working on. Again I just wanted to pass along what has worked for me.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #2 of 3 Old 07-08-2012, 06:22 PM
Very Helpful. Im looking forward to doing my headgaskets and studding with the cab on.
Alak is offline
post #3 of 3 Old 07-08-2012, 09:30 PM
Country Mav's Avatar
Quoted: 2 Post(s)
Thanks for the tip! I may need to do this on the next one!
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
