Needing heater hose tee for coolant filter! - Ford Powerstroke Diesel Forum
Old 07-08-2012, 04:19 PM
Guys I haved looke everywhere for a brass 3/4" x 3/8" x 3/4" tee. I bought a coolant filter head from a guy on here and was gonna make my own coolant filter setup! I have lots of fittings hoses and other junk laying around the shop and figured it would be a piece of cake! But I cannot find that Tee in brass. I have found it in plastic and nylon! I know the rating on the nylon is like 150 degrees so it is out. But I dont know the rating on the plastic. It is sold as a heater hose tee at Autozone but I dont know the temp ratings. My local Lowes doesnt have anything.
Old 07-08-2012, 04:26 PM
Do NOT use plastic. Read this thread and look at the pics throughout and you'll be glad you didn't.
PMM Coolant Filter Alert
Good luck with your hunt and here's a bump for ya!
Old 07-08-2012, 04:48 PM
Look at PEX fitting at the hardware store. I think I used a 1x1x1/2 for the supply on my filter setup.
Old 07-08-2012, 04:57 PM
Nothing wrong w/ plastic tees IMO (properly rated plastic), but you can get brass tees off of the internet:
http://www.pexuniverse.com/store/pro...x-reducing-tee
Old 07-08-2012, 04:59 PM
Originally Posted by bismic View Post
nothng wrong w/ PEX, but you can get brass tees also
Aren't all PEX fittings brass?
Old 07-08-2012, 05:03 PM
Yeah, I meant to type plastic and put PEX, corrected myself, but too slowly! Brass is certainly safer, but I think PMM is taking advantage of the emotion from some of Dieselsites tees failing.
Old 07-08-2012, 05:18 PM
I made mine out of brass with reducers, not pretty but it works.
Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App
Old 07-08-2012, 05:19 PM
Yeah I looked at the pex fittings, but I didnt know if the barb on them was good enough to hold the hose on! I may just go and get one of those and give it a try! I guess the system will only have 16psi so it wont have alot of pressure! The heat was my only concern!
Old 07-08-2012, 05:22 PM
I've been running the PEX fitting for the supply for 20k with no problems. The one I used was a real tight fit also.
Old 07-08-2012, 05:23 PM
Hasn't Dieselsite always used barbed brass fittings?
