6.0 diesel performance upgrades? - Ford Powerstroke Diesel Forum
Old 07-08-2012, 03:50 PM
So far on my 6.0 I have a 4inch Mbrp 4 inch exhaust with 5 inch tip a bully dog cold air intake with the bully dog power pup chip( economy setting) .. What else would have think would be next ? I was thinking a water injection kit? Any other ideas?
Old 07-08-2012, 03:54 PM
KING of BLING!
I would do an SCT tuner with custom tunes. Matt@Gearheadperformance, Eric@innovativediesel, Vivan@Quicktrickperformance, and Truck Source Diesel to name a few. Your truck will run way better with custom tunes designed for your truck specifically.
Old 07-08-2012, 04:00 PM
+1000 for custom tunes.
Old 07-08-2012, 04:01 PM
I would put a coolant filter system on an pick up the edge cts so you can check how good your motor is
Old 07-08-2012, 04:03 PM
The Silent Service
I second the recommendation for an SCT tuner and a good monitor (Edge Insight CS/CTS). Custom tuning is the only way to go for a 6.0L that will keep the transmission issues to a minimum.
What Intake are you running?
Past that, I offer the following thread:
Write Up: Power Potential of the 6.0L PSD
However without a monitor, you can't prevent issues before the 6.0L has major failures:
Write Up: Monitoring the 6.0L PSD.
Old 07-08-2012, 04:32 PM
What's the coolant filter system
Doing for u? How's it helping going good?
Old 07-08-2012, 04:35 PM
What's the coolant filter doing for u how is it help? And can anyone give me info about this edge insight cts
Old 07-08-2012, 04:40 PM
The Silent Service
I have all the information for the Edge Insight, in the monitoring thread I've linked in my previous post.
The coolant filter, most of which are a by-pass design, helps collect the casting sand, debris, and silicate gels out of the system. It will lengthen the life of the oil cooler and water pumps in these trucks.
Old 07-08-2012, 04:54 PM
How much does the coolant filter cost ? You know
Of a good website to order this from?Thanks for your help... Also how
Much are these tunes with the sct chip? I have a sct sitting under my back seat I also have a bully dog chip too
Old 07-08-2012, 05:06 PM
Also what is this blue spring I've been seeing
