injectors changing
has anyone changed injectors in a 2004 van ? Doesn't look like you can do it with engine in ?? Thanks Dave
yea its possible. calls for almost 10 hours.. TAKE YOUR TIME make sure copper washer comes with the injectors or you'll be doing it twice
Last edited by powerstrokedieself250; 07-07-2012 at 08:57 PM. Reason: added info |
Thank YOU !!
for the right bank of injectors you will need to remove the left hand motor mount and let the engine lay on the frame. you can't properly remove the valve cover without doing this
This might help.
You saved the day because NO ONE here knew how that worked so Thank You Again you saved the day !! Dave
