6.0 Towing Smoke - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-06-2012, 07:25 PM Thread Starter
6.0 Towing Smoke
Hi,
I have a 05 6.0. Everything is stock except for a 4" down pipe and then a 5" Straight exhaust.
My issue is when towing a trailer. When I take off from a stop sign I almost always get a cloud of white smoke that turns to black very quickly. Then it is fine until I come to a stop sign again. At idle there is now smoke.
Truck also blows a little bit of white smoke on initial start up and then after its warm it goes away.
Just wondering where to start on this thing, I cannot think that this is normal as I don't see too many other trucks doing this.
Any help would be great.
Dude Man is offline
post #2 of 18 Old 07-06-2012, 07:46 PM
Do you have any guages or a cts to watch your vitals?
06 F-250 Lariat
-ARP's
-EGR Delete w/ up-pipe
-Updated stand pipes, dummy plugs
-6.4 Banjo's
-175cc injectors over stock nozel
-SCT X3 w/ SRL
-PMM Coolant Filter
-Edge CTS
-Leveling Kit
-35's
-OEM 20's
-Blue Spring Update
-AEM CAI
-CAT EC-1
-Rotella T6
-Straight Pipes
wagner22 is offline
post #3 of 18 Old 07-06-2012, 07:58 PM
southend's Avatar
^^^^ this, essential on the 6.0. May be ficm.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 18 Old 07-06-2012, 07:59 PM Thread Starter
I have a boost gauge, transmission temp gauge, exhaust temp gauge. All are glow shift. I also have a fuel pressure gauge but I think something is wrong with it, as it is pegged out all the time.
Debating getting a monitor but I may need that money to fix truck. Seems like I can never get better 12mpg towing or not towing.
Doesn't seem to blow smoke when not towing. Will be towing around 12000lbs tomorrow morning and will watch gauges and tailpipe more closely
Dude Man is offline
post #5 of 18 Old 07-07-2012, 07:15 AM
southend's Avatar
This is why you need a monitor, without it you may be throwing part at your problem.
Write Up: Monitoring the 6.0L PSD.
southend is offline
post #6 of 18 Old 07-07-2012, 02:33 PM
EGR valve needs a cleaning!
niftytwofifty is offline
post #7 of 18 Old 07-07-2012, 07:03 PM Thread Starter
After driving around today, I noticed that upon acceleration from stop sign my truck lags a bit until I build boost. Seems as if turbo isn't winding up as fast as the fuel going into her. Where should I look now?
Dude Man is offline
post #8 of 18 Old 07-07-2012, 07:32 PM
Razorsedge's Avatar
White smoke at idle? My money is on a blown EGR cooler. Park the truck with the nose down overnight and pull the EGR valve out in the morning. If the valve or inside of the intake manifold are wet you've got your answer. As suggested already the EGR valve may need a cleaning, this would be a good time to do it.
2005 F250 4x4 King Ranch 6.0
Two tone removed, Quad Captains, High idle mod
Edge Insight CS w/ EGT, fuel PSI, and turbo timer
4" turbo back straight pipe, Dieselsite coolant filter
BPD FICM, '03 turbo, IPR gen2 delete, Zerex ELC
Goodyear Duratracs, Tuned by Matt@Gearhead
Razorsedge is offline
post #9 of 18 Old 07-07-2012, 07:49 PM Thread Starter
Well I do have a bullet proof egr cooler, just had heads done in February and it looked good. Then about 2 months ago I had a new oil engine cooler installed. Just recently I noticed a water gurgling noise around glove box at times. Normally under heavy load upon acceleration.
Dude Man is offline
post #10 of 18 Old 07-07-2012, 07:58 PM
I had the same problem last year. White and black smoke at acceleration. Ended being a inner turbo seal.
Maybe check the turbo for play and see if there's oil in it?
lethald is offline
