as long as - Ford Powerstroke Diesel Forum
Old 07-06-2012, 01:26 PM
as long as
As long as I have the engine down putting in a new egr and oil cooler I decided to put in new injectors , fix the front seal , and have the FICM reworked . Does anyone have any input as into what else should be done at this point ??
Thanks Dave The van is a 2004 6.0 with 135 K on it .
Old 07-06-2012, 06:29 PM
War is the answer!
Look at your ICP sensor and get your turbo cleaned not to mention your boots and tubes need inspection and probably cleaning. Have you changed out your coolant to an ELC? Coolant filter? Monitoring solution?
