BPD VGT wiring/
Has anyone tried this VGT wiring harness update? I can solder but I know it would be a PINA trying to do it up on top of the engine bay, lol. my truck is a 2004
Ford VGT Turbo Control Solenoid Pigtail Harness Can this be installed without removing a bunch of junk? BulletProof Diesel Fan Clutch Wire Harness Saver Thanks for the help |
My VGT harness got busted when my PowerMax got installed, so I had this one installed. The pigtails are plenty long enough, so it isn't too bad.
As far as the clutch wire harness saver, I had mine installed when my shroud and everything were removed to install my BPD water pump. I could barely fish my hand in between the shroud, so I would imagine it would at least need the shroud removed, which requires removing the fan blade. Not too involved. |
thinking back now, yeah your right, dang it. don't you hate it when you have to take things apart like 4 times to replace on little thing
the solenoid harness I might just do to be safe anywas, so that isn't like a plug and play thing. I'll actually have to solder like one of the reviews says? |
10-4 gonna order that up,
pretty sure I have a sticky turbo so it needs to be pulled and cleaned (151k on her never touched). So when I yank it out to clean Im gonna do that new VGT wiring harness |
Good deal. Keep us posted on what you find!
and as long as i'm yankin the turbo out might as replace them old inner cooler boots
going with riff raff boots all around |
