P1378 code ?? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-05-2012, 03:42 PM Thread Starter
elm302's Avatar
Feedback Score: 3 reviews
P1378 code ??
Just noticed today according to my gryphon ficm tuner I'm getting the p1378 code which means low voltage to ficm. I checked my ficm output and am getting no less than 48 volts even when cranking. My ficm input was reading 11-12.5 volts. Does the input seem normal ? The truck runs starts idles great. I'm getting great fuel mileage aswell no blue or white smoke. Just curious as to what's causing that code to keep popping up after I clear it.
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #2 of 2 Old 06-20-2016, 03:48 PM
Quoted: 19 Post(s)
Garage
I realize this post is nearly 4 years old, but I have the same issue.
Truck starts, idles and runs great. I recently decided to try and get to the bottom of my P1378 DTC that keeps rearing its ugly head. I went as far as replacing my batteries (previous ones were ~ 4 years old, but still worked great). I also replaced the FICM relay (F8OZ-14N089-AA).... but the P1378 keeps coming back.
AutoEnginuity reports my FICM Logic Power never drops below 10V... even then, the lowest voltage reading is during cranking with the glow-plugs still on and only for a fraction of a second. The always truck starts within 1 or 1.5 seconds of cranking, and FICM Logic Voltage jumps up to 11.5V-12V right away. FICM Main Power stays steady at 48V at all times...
The FICM Tech Guide (https://swampsdiesel.com/files/Fordficm.pdf) seems to indicate that P1378 is only triggered when FICM Logic Power drops to less than 7 volts. This is not happening on my truck... or at least AE doesn't see it.
Only thing on the PCM out of the ordinary is a Edge Platinum Juice with Attitude module. Not sure if this could be a factor.
I apologize in advance if this has already been explored and answered...
Thanks guys!
vitamin joe
2004 Ford F-350 Lariat FX4 4x4 SRW
308124km (191459 miles) as of February 19, 2017
15.46 avg mpg
Delo ELC - CAT EC-1 . EGR Cooler Deleted . Edge Juice Platinum with Attitude . Blue Spring Upgrade . Sinister Diesel Coolant Filter. AFE Magnum FORCE PRO 5R Stage-2 CAI . Warn Premium Locking Hubs
vitaminjoe is offline
