Cleaning Mods? - Ford Powerstroke Diesel Forum
Old 07-05-2012, 01:02 PM
Cleaning Mods?
hey all,
im fairly new to the site.. and i checked all the tech write-ups for the 6.0 already.. so here my questions..
i just bought the truck and i plan on doing alot of preventative maintenance that are on the tech section... is there things i can take apart and clean out debre to make engine run better (my truck runs great, but for all i know it could run way better..) first 6.0 i ever had..
i know about cleaning egr.. ive checked the cap and resivour for puking (nada there) can i clean pickup tube for turbo or anything else like i would on my 7.3?
much help would be very appreciated.. i have 2 weeks to "clean out everything.. change fluids.. and leveling kit.. before i take family on outerbanks vacation from nj
Old 07-05-2012, 01:35 PM
Feedback Score: 3 reviews
You can clean the EBP tube and MAP hose/intake fitting.
Old 07-05-2012, 01:40 PM
ok cool.. thx for the reply in helping.. locations of the parts would be helpful also if u dont mind.. maybe a pic or 2?
Old 07-05-2012, 02:06 PM
Here is the 6.0 bible, start with the 2003 and work you way upto 2005.
http://www.forddoctorsdts.com/articl...icle-06-08.php
This first pic is the MAP sensor, has a hose going from it to the intake manifold. The intake fitting and hose can get clogged with soot. The EBP tube will be on the driver side exhaust manifold, the metal tubing going from it to the exhaust manifold can get sooted up. The tube will go to the EBP sensor location will depend which year truck. Early years has sensor mounted to thermostat housing and later years has it below the FICM.
