Mods - Ford Powerstroke Diesel Forum
post #1 of 45 Old 07-05-2012, 01:09 AM Thread Starter
Mods
So, I have been a powerstoke owner for just a little over a week, and have been on here regularly since then, and was here before while researching my purchase. Anyhow, I have read many posts by people with signatures with all of their mods. Most of them are self explanitory, Some I've figured out, but I'm still not sure what a lot of them are. Was wondering if someone could fill me (and other noobs) in! Would like to compile a list of them, what the benefits are, and how to do them! THANKS
Out of Cash mod?
Zoodad?
Harpoon?
CCV?
Banjo bolts?
etc...
maberle is offline
post #2 of 45 Old 07-05-2012, 01:25 AM
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
Gauges or some type of monitoring, believe me youre gonna need it!!!
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #3 of 45 Old 07-05-2012, 01:32 AM
UrbanAssaultVan's Avatar
Out of Cash mod?
Zoodad?
Harpoon?
CCV?
Banjo bolts?
etc...
in order
* probably a joke
* intake mod called zoodad. search it
*dont know
*crank case vent mod
* 6.4 banjo bolts instead of 6.0 banjo bolts.(considered an upgrade)
I dont consider half of these things to be mods. To me a mod is a turbo upgrade, injector upgrade, headstuds, ect. Using banjo bolts from a 6.4 is kinda a revised part. alot of people have things like "blue spring mod, and dummy plugs, ect listed as mods when they are actually just revised or replaced parts that have been updated or simply just wore out and have been replaced. It is kinda like saying I have an "oil cooler mod" since I have the updated ford oil cooler. Well no I dont, I just replaced my oil cooler lol. the zoodad is something to the extent of pretty much cutting things out of the way of the intake to allow more strait line cool air to the filter.Never saw it as something that would be worth it but I dont know. maybe some other guys with the Doodad zoolander mod can chime in. (who comes up with these names? lol. like calling head bolts "stock sticks" lol. where I come from cams are the only thing being refered to as sticks and they are bumpsticks lol. I am still learning the terms as well haha. welcome!
2006 6.0 PSD Van
SCT,DiamondEye,Autometer,king ranch,and other crap that nobody cares about...
UrbanAssaultVan is offline
post #4 of 45 Old 07-05-2012, 01:33 AM Thread Starter
Oh ya, I have the CTS on the way, and have done a lot of research into all of the normal mods, was just wondering about those oddball ones. I just wanted to start a list of them so I (and others) knew what they meant. I've already done the ZooDad, just so many different Mods out there and I'm having trouble making sense of some of them!
maberle is offline
post #5 of 45 Old 07-05-2012, 02:46 AM
Harpoon - cutting the vent tube in the fuel tank to reduce the backpressure when filling up. After doing it, you can fill up at the 18-wheeler pumps and fill it to the brim very quickly.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #6 of 45 Old 07-05-2012, 05:30 AM
I thought stock sticks meant stock injectors..
Originally Posted by UrbanAssaultVan View Post
in order
* probably a joke
*dont know
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #7 of 45 Old 07-05-2012, 05:40 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Out of Cash mod?
Zoodad? Cuts a hole in front of your intake in the header panel because it's dumb and closed up stock.
Harpoon? Cut off the fill and vent tubes in the fuel tank so that you can fill the tank fuller without it clicking off sooner. Nothing to do with back pressure
CCV? Crank case normally vents into the intake leaving oil residue in the whole system. The CCV mod reroutes it to dump to the atmosphere usually.
Banjo bolts? Upgrading the stock ones to 6.4 motor ones. The 6.4s have bigger holes in them
etc...
Sticks just mean injectors usually. Shorter to type.
In Red.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 45 Old 07-05-2012, 12:24 PM
hmm, I thought people were talking about head bolts lol. ok injectors it is then. so why not just say stock injectors lol
2006 6.0 PSD Van
post #9 of 45 Old 07-05-2012, 02:06 PM
And type 3 more letters then we have too? We are busy and have things to do....
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #10 of 45 Old 07-05-2012, 02:33 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Don't forget about the "High Idle" mod.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
