How should i drive my 6.0 - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-01-2012, 05:20 PM Thread Starter
Daxman's Avatar
My truck is a 2006 with the 6.0 and i was just wondering the best way to drive it. I hear people say drive it like you stole it but im always afraid im going to break something. The truck is completely stock, and my commute to work everyday is only about 2 miles there and 2 miles home. Should i be opening this thing up everyday to keep the turbo cleaned out ?
Daxman is offline
post #2 of 16 Old 07-01-2012, 05:26 PM
First of all the 6.0 is not a grocery getter and should not be used that way. Our trucks run on nothing but the batteries for the first few minutes while the glow plugs are on. Unless you have REALLY good batteries this is detrimental to the ficm. You can drive it how ever you please, but they do like to run and not grandpa'd. At least once a week open it up at wot to flex the veins in the Turbo.
Sent from my DROID RAZR using AutoGuide.com App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #3 of 16 Old 07-01-2012, 06:37 PM
squirtgun's Avatar
Drive it like you stole it
2003 6.0L F250 4x4 Lariat
Fog Light Mod,High Idle Mod,Zoodad,Hose clamp taligate mod,08 rear bumper,Sinister EGR delete,ELC EC-1 coolant,Edge Juice,MKM(Sinister)coolant filter,HFCM drain plug upgrade,diy FICM repair(steady 48.5v now),DIY CCV mod,Torque Pro,Blue spring upgrade,Aluminum radiator,05 headlights,LED foglightd
Wish List/Things to do
Y-pipe,fuel pressure gauge,diy oil bypass(maybe centrifuge),oil pressure gauge
squirtgun is offline
post #4 of 16 Old 07-01-2012, 06:39 PM
Rjstepp's Avatar
Rick
2003 F350 cclb 6.0l 126,000 miles
SCT X2 running matt's srl
edge insight cs, egt probe
egr delete
Sinister coolant filter
4" turbo back diamond eye exhaust
smoked cab lights and mirror lens
Cut '05 grille and rhino lined bed
Leveled on 35" toyo m/t's
Rjstepp is offline
post #5 of 16 Old 07-01-2012, 06:40 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1119 Post(s)
Feedback Score: 6 reviews
Run the piss out of it, that's what I do!!
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #6 of 16 Old 07-01-2012, 06:43 PM
MWilbur516's Avatar
This is good advise, but if you only drive it 2 miles before shutting it down everyday, you better drive those 2 miles like a herd of f*cking zombies are chasing you. Constant short trips are extremely detrimental to these engines.
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #7 of 16 Old 07-01-2012, 08:16 PM
Red '97's Avatar
thats not really enough time to even hit operating temp though.... youll break things way faster if you rod it before its warmed up... i wouldnt commute my 7.3 2 miles a day, id probably take my horse if that was my commute haha
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #8 of 16 Old 07-01-2012, 08:22 PM
RIP Cam!
I agree, or you could just walk.
post #9 of 16 Old 07-01-2012, 08:36 PM
back to business
07OUTLAW's Avatar
Walk or ride a bike the 2 miles to work
Save the truck for longer trips, and AFTER it's at operating temp........ beat the hell out of it!
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #10 of 16 Old 07-01-2012, 09:26 PM
headviking's Avatar
Before you drive it like you stole it, make sure the engine is at normal operating temp first.
If your commin, it's over. If your stroken, it's just started.
2007 F250 6.0L PSD Lariat - Dieselsite Coolant Filter - Bilstein Shocks - Blue fuel pressure upgrade spring - Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - HFCM Water Separator Drain Plug Upgrade - ARP studded - Engine Oil (Rotella syth) - Rear Diff. & Front Axle (Royal Purple)
HeadViking
Helpful Links:
headviking is offline
