injectors changing
What is the best way to make sure you don't leak diesel in the cyc or get dirt in the cyc while putting new o rings on the injectors ?
Thanks Dave |
Chances are you'll get oil over diesel in your piston. When you take off the hpop rail it will leak out. I just keep everything as clean as possiable and cover the holes with clean rags.
You'll get oil or fuel in it. Pull the GPs and crank over the motor to clean them out before you crank it over for the final time.
