HIDs wont stay on???HELP - Ford Powerstroke Diesel Forum
Old 06-30-2012, 10:27 PM
Hey guys finally got around to attempt to installing my DDM tuning hid kit. I got everything hooked up and the bulbs were fine. the second time and every time after that i turn on the headlights and they will flick on for maybe a second then go out.
Old 07-01-2012, 04:58 AM
Do you have the constant power wire ran? Mine do this so I called and they send me the wire. It should fix your problem.
Old 07-01-2012, 10:08 AM
You mean a relay?
Old 07-01-2012, 05:50 PM
Feedback Score: 3 reviews
I had the same problem with Ddm kit ended up being bulbs. They sent me new ones to replace them. Keep in mind the bulbs were brand new and still didn't work.
Old 07-01-2012, 05:51 PM
Almost sounds like a ballast issue too. Swap everything around and see if you can pin point the problem
Old 07-01-2012, 06:01 PM
I had the raptor kit hooked up maybe ill use the slim ballasts i ordered for my fogs
Old 07-01-2012, 06:12 PM
Should i buy the relay?
Old 07-01-2012, 10:56 PM
Ok got some good news and bad news, used my fog slim ballasts for my headlights and both work fine now. For the hell of it i used the raptors i originally tried for the headlights for the fogs and both worked even tho one of the ballasts didn't work for the headlights last night. Then the same thing happened with the fogs as the headlights, the one ballast worked fine on startup then every-time after that it didn't work. I tried one of the slim ballasts and the light worked fine so i know its not the bulb. Would the ballast be broken but be able to do that twice? (be fine the first time used on a bulb but every-time after that only flicker and not stay on)
Old 07-02-2012, 12:36 AM
I'm not going to lie. I had the same problem with my HID kit. I had the slim kit and my left one would turn on the off. So I turned my lights on before I started the truck. Worked fine, I'm guessing it surged too much to give it the power it needed. Idk. It was either that or left the lights off, then pull the brights on manually to see if they stayed on. If they did I switched the headlights on then let go of the brights.
That's why I ditched the HIDs. I might try the retro-solutions kit down the road, until then my halogens will work.
Old 07-02-2012, 01:31 AM
im going to call ddm and return the two raptor ballasts and get 2 slims anyway since i need the mounting holes to secure them
