Remote starter switch for troubleshooting - Ford Powerstroke Diesel Forum
Old 06-29-2012, 09:41 PM
Is it just a momentary contact switch wired across the starter solenoid?
I'm wanting to check for blowbly back into my fuel systems by watching for air bubbles in the upper fuel filter housing while cranking key OFF. I've read about it in DTS and seen a vid on youtube by a Ford tech. Think it's called the Compression bubble test.
Old 06-30-2012, 04:54 AM
Glow Plugs Only
On my 05 there is a yellow wire that runs along the right side fenderwell by the vacum pump. Take the connection appart and jumper the male end to battery positive key off and thats all you need to do. I hook my remote switch to the posoitive batt terminal and other end to the male wire terminal.
