EOTs - Ford Powerstroke Diesel Forum
Old 06-29-2012, 05:53 AM
EOTs
Flushing the cooling system as we speak (truck is at the dealership) and I am cautiously optimistic that it will help what I think is a significantly clogged oil cooler. Reasoning behind my thoughts are that the EOT never gets above 217° (ECT is 187°) in the morning on the way to work but the same trip back home gets the EOT to 232° (ECT is 195°). In yesterdays heat of 97°, the EOT/ECT was 240°/202°! Does, or maybe should, the outside temperature affect the running temperature of the truck that much? I already have an appointment at Hallas Performance for an oil cooler-ectomy and replacement if the flush is unsuccessful - just wish I didn't have to spend another $1000 or so to get something done that should've been done when the EGR delete was done. OK, <rant off> for now...thanks for the ear...!
Old 06-29-2012, 06:39 AM
The Silent Service
You need to have the oil cooler done at the dealership now.
You are only going to break more crap loose and clog the cooler more with this flush.
If this is the '06 in your sig with the EGR delete, you don't have HG's to worry about, but you may have an oil cooler rupture if you don't take care of this now.
You are 100% correct that anytime you do an EGR cooler job, the oil cooler should be rebuilt or replaced at the same time.
Old 06-29-2012, 06:54 AM
War is the answer!
THe reason EGR coolers go bad is becouse the oil coolers go bad first. he is right to tell you to get the oil cooler replaced now.
Old 06-29-2012, 08:57 AM
I called the dealership an authorized replacement of the oil cooler - thanks for the advice; it is probably the best choice to get it done now and not get anything else hurt if I continue to drive it. It is a good running and looking truck and I intend on having it for a long time. Once again, thanks for all the advice - it is truly appreciated!
Old 06-29-2012, 02:14 PM
Hope the stealership at least gives you a peck on the cheek or a hug after you empty your wallet with them. Been there, done that....but didn't get anything other than the door being held open for me.
Old 06-30-2012, 05:13 AM
I agree to this. I had my EGR cooler deleted and didnt get the oil cooler replaced and three days later, I was back in the same boat with a new HPOP, oil cooler and one injector So double the labor.
Old 07-06-2012, 04:56 AM
After oil cooler replacement, oil temps hover right around coolant temp now and rarely go over 200°F - had a minor coolant leak but found a broken clamp and replaced and now all is good. Thanks, again, to colo_dually for his swift kick in the a** and gettin' it fixed!
Old 07-06-2012, 05:03 AM
The Silent Service
I'm here to help partner.
Old 07-06-2012, 06:32 AM
What did the dealer put back in your cooling system? Is it the Motorcraft gold? And did they use tap water?
Old 07-06-2012, 08:51 AM
Also, I'm curious what a dealership charges for that work, compared to what the diesel performance shops charge.
Glad to hear that it is running better! Congrats.
