The 6.0!! - Ford Powerstroke Diesel Forum
post #1 of 29 Old 06-28-2012, 11:48 PM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
The 6.0!!
I have had my 04 F250 for 4 years now its got 105k on it and want to start upgrade. For the most part its stock besides 4'' lift a true 4" exhaust and cold air intake. I have only had 2 problems with it #7 injector and FICM but I bought an rv thats going to be towed on ling trips often also have horses that I tow a lot. My question is where do I start head studs egr delete? The diesel shop where I live wants almost $10,000 to do the work, his labor is cheap but parts mark up is out if control. Is it at possible for me to do(I am very mechanically inclined). Just want to know where the bedt place to start is..
04fording is offline
post #2 of 29 Old 06-29-2012, 04:17 AM
f350powerstroke's Avatar
Personally, if it ain't broke, don't fix it!
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #3 of 29 Old 06-29-2012, 04:23 AM
ars5147's Avatar
Quoted: 118 Post(s)
Yes, studding it is possible to do yourself. It would just be time consuming, so set aside some days to work on it if you decide to. But really, if nothing is wrong with it, you really don't have to stud it. EGR delete should be at the top of the list.
If you don't have something to watch oil and cooling system temps, that should be the top of the list there. That will let you know where to start at if anything does need addressed.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #4 of 29 Old 06-29-2012, 04:41 AM
Rick C's Avatar
In agreement with all of the above. Don't mess with head gaskets/studs till necessary...check your ect/eot deltas...drive it. FWIW i'd go back to the stock air cleaner.
2005 F-450 CC Fontaine Conversion
(It's the heavy GVW one with the Dana 135, 4:88's and bigger brakes)
Link Air Ride Suspension
Banks Stuff (CAC, Exhaust)
EDGE CTS
SCT x3 with Eric's tunes
Bullitt Proofed (EGR mod, Remote oil cooler/filter, Water Pump, 7.3 fan clutch conversion)
ScanGaugeII
Odyssey AGM's
High Idle Mod, CCV Mod
ARP studs...Finally
More $$$ to be spent i'm sure!
Rick C is offline
post #5 of 29 Old 06-29-2012, 05:28 AM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
So leave as is? For sure going to do the delete and sct. The thing is i don't want to wait till the head gaskets blow and have to replace the heads.
post #6 of 29 Old 06-29-2012, 07:46 AM
DieselV8's Avatar
Most cases you don't have to replace the heads, you just need to check them to make sure they are true. You might have to get them milled.
06 F250 Crew Cab, Lariat-FX4, ScanGauge II, High idle mod, Heated mirror switch mod, Sinister bypass oil filter and coolant filter, Fumoto valve, Zoodad, Blue Spring
DieselV8 is offline
post #7 of 29 Old 06-29-2012, 08:20 AM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
So I'm getting that I don't need to have studs until the head gaskets fail. But I can do the delete and sct for towing.
post #8 of 29 Old 06-29-2012, 08:40 AM
$10,000? I got a quote for around $4,000 to do studs, egr delete, new oil cooler, stc fitting, dummy plugs, standpipes, blue spring, and 6.4 banjos. That $4,000 includes parts, labor, and any machine work needing to be done to the heads. $10,000 sounds like A LOT of money.
2005 F250 CCSB FX4 Lariat
Gryphon Evolution
4" MRBP Dual Exhaust
Zoodad Mod
Dummy Plugs
Stand Pipes
STC Upgrade
Blue Spring Mod
6.4 Banjos
EGR Blockoff
8" Fabtech Lift
20" MKW M19's
40x12.5x20 Michelin X
TotalDoubt is offline
post #9 of 29 Old 06-29-2012, 08:44 AM
xu67585's Avatar
Quoted: 5 Post(s)
Garage
$10,000?! I only paid 12,000 for my whole truck.
Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App
2005 F250 SC SB
ARP Studs, RCD Egr Delete, Homemade Coolant Filter, Stand Pipes And Plugs, Banjo Fittings, Blue Spring,
STC Upgrade, FleetGuard ELC, Cat Delete, Zoodad Mod, CCV
xu67585 is offline
post #10 of 29 Old 06-29-2012, 09:00 AM Thread Starter
04fording's Avatar
Quoted: 8 Post(s)
Yeah he has 100% mark up on his parts just for the studs no labor is 825!! I'm in Washington and he is the only guy in town. Thats why I want to do it myself just don't have a way to lift the cab.
