f550
Looking at an 06 f550.
Whats the difference between this and a f350 ? Joe |
Mainly the brakes and rear axle I believe.....but someone else probably knows exactly the differences. The frame may be a bit beefed too.
Check your insurance before you get too serious about the 550. Probably have to register it as a commercial vehicle which costs a hell of a lot more to insure vs the 350.
As for the difference, much better brakes on the 550 and the sterling 110 rear axle and i think 4.88 was the only gear option. The frame is also a good bit heavier. Jason |
If you need a F 550, go one step more and get a F 650, most of those trucks come with a CAT 7 liter trubo diesel and a Real Allison trans.
Higher insurance, stiffer leaf springs, poor fuel milage, oh and lower back pains. Depending on usage you might have to register with Dept. of Transportation as commercial vehicle. Even my F-350 is higher on Insurance than a F-250
The 450 and 550 start out as a cab and chassis truck.
The frame is heavier/thicker, it's a straight rail type, flat frame behind the cab and only 34" wide (250/350 are 38") so to mount a pick-up box you need to add custom mounts. The main fuel tank is 40 gal and mounted behind the axle, so there is no place for a spare tire to go. There is also an optional 19 gal front tank (which my 450 has). Because of the narrower frame there is limited aftermarket available for exhaust systems that just bolt right on without some mods (mainly the tail pipe fitment because of the rear tank, also bolt on hitches have to be different for the narrow frame. Like others have said the axles and brakes are heavy duty, and the wheels are 19.5" 10 bolt with F or G load range tires. The '06 450 has a 16,000 GVWR and I think the 550 is 17,950 GVWR Because my 450 has a pick-up box my insurance is the same as what my 350 was, but I was told by my insurance guy that he couldn't do that with a 550. My 450 is perfect for what I use it for, hauling a slide in truck camper with a wet weight of 5000 lbs and pulling a cargo trailer behind it. Last edited by Arctic Fox; 06-30-2012 at 04:55 AM. |
Looked at a couple of f650's. All of them had air brakes. Don't want that.
Thanks for the great info.
Trying to get this one because it has a roll off box.. It fits with what I have been doing lately. Quote:
Why the poor fuel mileage ? Worse than the regular 6.0 ? Should I assume because the truck weighs more ?
Also, because it will be hauling, should I also be looking for a 15* delta, if i take it for a spin, unloaded ? And, does the 15* delta also apply when you are hauling/towing ? |
Look for less than 15* delta running empty at 60 mph on a flat road |
