Trans filter - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-28-2012, 05:09 PM Thread Starter
ParkCity.PSD's Avatar
Trans filter
My Trans temp seems to be running a bit high lately. I thought I'dtry changing the Trans filter and see if that helps. How much fluid should I get? I know it's on here but can't search on my phone for some reason...
06 F350 Lariat
Edge Insight CS
Blue Spring Update, EGR Delete, STC update, Stand Pipes and Dummy Plugs, Turbo feed and drain tube update, Sinister coolant filter, New stock oil cooler, Zerex ELC, RiffRaff Boots, Isspro Fuel PSI, DC Alternator, ARP Studs, Heads from Jared, OEM Head Gaskets, Yukon Dura-Grip Posi
Warren 155cc/stock injectors
SCT with tunes from Vivian
Western 8-1/2ft Pro Plow with UltraMount
Hansen Front Mount Snow Blower
ParkCity.PSD is offline
post #2 of 11 Old 06-28-2012, 07:41 PM
I think it's 8-9 quarts just draining the pan and changing the in-line filter. What temps do you consider high? May just be the warmer weather, no? Anyways, your supposed to change fluid every 30k miles and use mercon V. I got it from Ford but not sure where else to buy it.
2003 Ford F-350 FX4 SRW crew cab short bed
~Blue Spring kit
~6.4 fuel banjo bolts
~EDGE Insight CTS monitor
~Sinister Diesel Coolant filter w/ CAT EC-1 coolant
~Sinister Diesel EGR Delete
~Updated OEM turbo oil drain tube
~Updated HFCM drain plug
~Cat/muffler delete pipes
~SCT X3(Gearhead SRL)
~1.75" front leveling lift
~Bilstein 5100 shocks
~18" Pro Comp 1069 wheels on
295/70/r18 Nitto Terra Grapplers
PolishPstroker is offline
post #3 of 11 Old 06-28-2012, 07:46 PM
xu67585's Avatar
Quoted: 5 Post(s)
Garage
It took me 8 qts, orderd it from bumber to bumber. I dont remember the price but it has to be cheaper than ford.
2005 F250 SC SB
ARP Studs, RCD Egr Delete, Homemade Coolant Filter, Stand Pipes And Plugs, Banjo Fittings, Blue Spring,
STC Upgrade, FleetGuard ELC, Cat Delete, Zoodad Mod, CCV
xu67585 is offline
post #4 of 11 Old 06-28-2012, 08:16 PM
DRILLROCK's Avatar
I pulled the plug and drained it, then I started truck and let it run for 1 min. Then killed it and a lot more came out. I changed the filter up front, then put plug back in and it took 9 quarts of Mercon SP and I need about a 1/2 quart of SP to top it off. I run the Mercon SP cus its what written on the handle.
Jeff
2005 F-350 CCLB King Ranch 4 X 4
Airaid cold air intake box & filter
MBRP TURBO BACK 4" Exhaust
2 1/2" Rancho Coil Spring Front Level Kit
ReadyLift TractBar Relocation Mount
RanchHand Front Replacement Bumper
Ride Rite Rear Air Bags
ScanGauge ll
Dieselsites coolant filter
35/12.50/18" 10p Toyo open Country ll
RC Dual Steering Stabilizers
Atlas 40 from Ficmrepair
River City Diesel EGR Delete
Other Rides--06 Ford Expedition limited--96 Jeep Cherokee--08 GMC crew cab
DRILLROCK is offline
post #5 of 11 Old 06-28-2012, 08:46 PM
Brew_WY's Avatar
Garage
Mercon V is not the correct fluid for a 5R110 automatic. You need a Mercon SP spec fluid.
2003 6.0L PSD Excursion Limited 4x4
Edge Insight CTS w/Dash Pod, EGT, TT, Back Up Camera
AMSOIL with REV-X
AMSOIL Bypass Oil Kit
GDS Fuel Spring
Diesel Site Coolant and Transmission Filters
Brew_WY is offline
post #6 of 11 Old 06-28-2012, 10:41 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Mercon SP or Mercon LV. Ford has changed to LV. They can be mixed.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #7 of 11 Old 06-29-2012, 01:24 AM
Quoted: 7 Post(s)
As others have said - Mercon V is wrong and it will ruin your solenoids. Also, very little reason to change the interna; filter. It is just a screen. If it plugs up you jave trashed the transmission. Draining it from the plug and replacing the external filter is easy and quite sufficient.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 11 Old 06-29-2012, 07:15 AM Thread Starter
Thanks guys! I guess I know what I'm doing this weekend...
06 F350 Lariat
Edge Insight CS
post #9 of 11 Old 06-29-2012, 07:28 AM Thread Starter
Any tips on the filter? I know for oil and fuel filters it's motorcraft or racor only. Same with Trans filter? Or can I pick something up anywhere?
06 F350 Lariat
Edge Insight CS
post #10 of 11 Old 06-29-2012, 08:01 PM
Yea, sorry about that. My mistake, it is SP. Maybe it was Mercon V for the power steering.
~Blue Spring kit
