No steering stabilizer? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-28-2012, 09:14 AM Thread Starter
Korx's Avatar
Is it normal for these trucks to come from the factory without a stabilizer? I was looking under my truck the other day and knew something was missing but I couldn't put my finger on it. Then realized my truck doesn't have one. Normal?
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #2 of 9 Old 06-28-2012, 09:30 AM
RRF985's Avatar
They all came with stabilizers.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #3 of 9 Old 06-28-2012, 09:31 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 108 Post(s)
Feedback Score: 3 reviews
Yes...There were certain packages that included the stabilizer.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 9 Old 06-28-2012, 10:55 AM
jerg_064's Avatar
My XL didn't have one when I got it, and the tire side mount was bent in on itself. Though I'm the 5th owner . I just bought the Skyjacker kit with tie rod mounting plate/hardware included for around $70.
James
2003 F350 Ext.C LB, 6.0L, 4x4 6spd SRW
DIY egr delete, DIY 4" straight pipe, DIY coolant filter, DIY CCV mod, PHP FICM/ECM Rollback, SCT LW, SGII, Skyjacker Steering Stab, Rotella Ultra ELC, blue spring, etc....
jerg_064 is offline
post #5 of 9 Old 06-28-2012, 11:35 AM
They only come with a stabilizer if they are the 4x4 off-road
2004 Ford F-250 6.0 CC SB
  • Edge Evolution
  • K&N FIPK Intake
  • MBRP 5 in Turbo-Back
  • 6.4 Banjo Bolts
  • Blue Spring Upgrade
  • Zoodad Mod
  • Sinister EGR Delete
  • BPD Oil Cooler (Condenser Mount)
  • SCT SF3 with tunes from Matt
dwpayne is offline
post #6 of 9 Old 06-28-2012, 11:39 AM
My 03 4x4 did NOT come with one from the factory.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #7 of 9 Old 06-28-2012, 01:53 PM Thread Starter
Korx's Avatar
Do you guys think its worth it to put one on? Single or dual? Benefits?
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
Stock
Korx is offline
post #8 of 9 Old 06-28-2012, 02:15 PM
southend's Avatar
I think it is worth it. Single is good, double is better. Most especially with all the threads popping up lately about worn out steering boxes. Bigger tires, absolutely.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #9 of 9 Old 06-28-2012, 07:38 PM
DoubleDpsd's Avatar
This.
I found this one on xtreme diesel.com
Bilstein 5100 Series Steering Damper 24-158848
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
