hub and air-filter q's - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-27-2012, 02:57 PM Thread Starter
fatdoug's Avatar
so, my driverside front wheel bearing is on its way out, not too bad yet but in need of some attention soon. i was on ebay looking for replacements and came across this:
NEW OEM FRONT HUB BALL BEARING KIT 2005-2010 FORD SUPER DUTY 4WD #5C3Z-2B513-AA | eBay
i have previously had my hub out and if i remember correctly the bearing on the back side is held in by a sap ring, so what i was thinking is that this would be a replacement for it. i used the part number on tousley's website and it comes up as 08+. did they change much up front from 06-08? i was looking at my secretaries truck (08 6.4) and it looks almost identical.
second: afe stage 11: i changed my air filter last month so its basically brand new, when i did that i pressed the button on the airflow sensor, now on my hud its saying "check air filter". took a look at the filter and it still looks like perfect. should i just get a new flow sensor or is there some sequence you have to follow to reset that thing?
thanks
Regards
Doug
Black
2006(dec 05 build date)Reg cab Long Box 4X4 6SPD 6.
100,000 KM as of april 8 2012
3" lift
325's
blue-spring
Coolant filter
5" MBRP turbo-back straight pipe
harley buckets, centre console and gauge cluster
high idle
KCCO
fatdoug is offline
post #2 of 3 Old 06-27-2012, 04:22 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
The hubs on the 4wd units are non serviceable bearings, you will need to buy the whole hub assembly. With that said, I have heard that you can service the inside bearing, but not the front. IMO, your better off buying the whole assembly than just replacing the inside bearing and having a questionable outer bearing.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 06-28-2012, 12:53 AM Thread Starter
fatdoug's Avatar
ya, i kind of thought thats what people would say but i figured it might buy me some time, what about the "Chech Air Filter" on the HUD any advice?
Regards
Doug
Black
3" lift
325's
blue-spring
Coolant filter
high idle
KCCO
fatdoug is offline
