Am I Forgetting anything? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-26-2012, 09:02 AM Thread Starter
at0075's Avatar
I ordered all my parts from tousley today for my oil cooler replacement/egr delete. I ordered the following
Oil cooler rebuild kit
2 intake gaskets
Turbo mounting hardware
Fuel regulator spring kit
Updated oil drain line
6.4 banjo bolts
4 banjo washers
Egr delete on the way as well
Fleet guard elc cat ec1 coolant
Distilled water
I didn't order the new hard line turbo oil supply linr because I did not order the new oil cooler cover being mine is a early 04 and I had to update that as well.
Am I forgettin anything? Any advice before I start this task. I'm actually looking forward to it because I know I will learn a lot as I see different parts of the Motor. Where can I find the torque specs for bolts I will be pulling out? Thanks
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #2 of 11 Old 06-26-2012, 09:58 AM
Quoted: 5 Post(s)
Feedback Score: 3 reviews
You may want to do the stand pipes and dummy plugs while you are tearing things apart.
I would also replace the IPR screen while you are in there.
And I would advise HIGHLY that you get some restore and restore plus and flush THOROUGHLY before you pull the oil cooler and put in ELC coolant.
Lastly a coolant filter wouldnt be a bad investment.
Good luck!!
Todd
2005 Harley F-250 CCSB
True Blue Metallic
Engine: ARPs, OEM oil cooler, Bed plate reseal, OEM HGs, Stand Pipes, Dummy Plugs, STC Fitting update, Bulletproof EGR, Rotella Ultra ELC, Sinister Coolant Filter, Machined stock heads, Blue spring
Exterior: Nitto Terra Grappler 295/60/20s on stock Harley 20s
Interior: Edge Insight CTS w/ EAS Fuel Pressure & EGT
Trans: PI Stallion, Billet input shaft, new clutches, 08 pan/filter
white59rt is offline
post #3 of 11 Old 06-26-2012, 10:27 AM Thread Starter
at0075's Avatar
My truck is an 04 so I don't have to do stand pipes and dummy plugs i didn't think. I wasn't aware I need a ipr screen? Is something that has to be done just preference? I put in my order. Guess I could call tousley back. I'm working on findig the restore and vc9 as well as coolant filter. I have everything to make my own but trying to find the filter and filter head. Thanks for the advice
at0075 is offline
post #4 of 11 Old 06-26-2012, 10:32 AM
Jayson41's Avatar
check the HPOP screen while your there as well, easier to just replace since you will be looking at it.
Bullet Proof Diesel Semi Bullet Proof Kit - Diesel Site Coolant Filter - Banks Monster 4" Exhaust - High Idel Switch - 2.5 inch Leveling Kit - 295/70/18 Nitto Trail Grappler M/T's - Amsoil
Jayson41 is offline
post #5 of 11 Old 06-26-2012, 10:53 AM
Quoted: 5 Post(s)
Yes the 04 has stand pipe and dummy plugs as far as I know. I think the 03 was different though.
The thing I dont think you need is the STC fitting that was an 05 up deal.
The IPR screen is preference but I am having mine replaced for good measure while its in the shop. I am going through all of this right now
Todd
True Blue Metallic
post #6 of 11 Old 06-26-2012, 10:59 AM Thread Starter
at0075's Avatar
Is this what the oil cooler sits on top of? My oil cooler kit came with a screen but I'm guessing its or the cooler itself. Do I pour in oil to the hpop before I put it back together?
at0075 is offline
post #7 of 11 Old 06-26-2012, 11:01 AM Thread Starter
at0075's Avatar
Todd
It's a early 04 which has the 03 motor and to my knowledge I don't have to worry about them? Not doubting you at all. Anyone else care to chime in?
at0075 is offline
post #8 of 11 Old 06-26-2012, 11:16 AM Thread Starter
at0075's Avatar
From what I've read if the icp sensor isnt on the valve cover, which mine is not, you don't need to update stand pipes. Dummy plugs aren't necessary either. Would love to hear others chime in on this
at0075 is offline
post #9 of 11 Old 06-26-2012, 12:57 PM
Quoted: 5 Post(s)
You are correct - your truck just said 04 so I assumed it was in need of the new parts as 04-07 needs it done, or should have it done.
Good luck - sounds like you have researched most of it and are ready to tackle it
Todd
True Blue Metallic
post #10 of 11 Old 06-26-2012, 01:00 PM
Send a message via Skype™ to bwmtnbiker
I hope he doesn't get mad that I'm posting his link with out asking but, colo_dually has a great write up for bullet proofing. He just helped me out a lot
Write Up: Bullet-Proofing the 6.0L PSD.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
