Tire Pressure
What tire pressure are you guy's running. I have Toyo's 255/85/16. A tire shop said that when not towing or hauling that 40PSI is perfect for ride and tire wear. What do you think?
I have 35" nitto trail grapplers, and I run 65psi for the street daily driving and towing, and 30 if going to the desert and 15 front and rear when towing the bronco at the dunes.
Should be running 45 front and 40 rear unloaded and I wouldn't go higher than 50 when towing (in a proper E rated tire). You're going to kill your ride going higher than that.
I am running an E rated tire and with my bilstiens and 65psi my ride is just fine. I think from the factory on the sticker in the door, these trucks call for about that anyway.
So it seems for a 4wd F250 SRW:
80psi rear =3415 lbs per tire x 2 = 6830 lbs (your rear axle rating) 55psi front = 2600 psi per tire x 2 = 5200 lbs (your front axle rating) Is what the factory calls for with stock E rated tires. |
I am running Bilstiens and I have had it at 65 and was a really stiff and bumpy ride. I lowered it to 50 on all four yesterday and was amazed at the ride. Very nice. I'll try that 40 rear and 45 front and see and re-post. Don't want to shorten the life of my Toyo's at $1200 a set. Thanks for the info.
75 psig in the original E rated tires. Got almost 80k miles out of them
I have no lift.bone stock on 20's i was satisfied with 45000 on goodyear wranglers
I have 75psi all the way around
I run i think 65front and 72 rear. that plus rotating the tires every 5k has kept nice even flat wear.
I may lower them for my trip to VA beach this weekend and see how my mileage does. |
