Buying a truck with an auxiliary fuel tank. Questions
I should be buying a 2005 4x4 f250 crew cab this week. It's a pretty clean truck, at a fair price. The owner towed a hitch tow hauler, I believe, and had a 100 gallon auxiliary fuel tank installed, in the bed. It's a short bed, and I'm pretty sure that it would have to be removed for me to be able to tow a fifth wheel toy hauler.
Any opinions on if it would still work with the fifth wheel hitch? It looks to go to about the forward part of the wheel wells, and is not angled like some of them are. It looks square. If I do need to remove it, do they typically install in a way that there will be holes to fill? And (last question ), are they typically worth selling if I do have to remove it?The truck is on Auto Trader right now, so I'll see if I can post up a pic. Thanks very much for any opinions or thoughts on this. |
i think it will work as the tank sits infront of the wheeel wells. where as your 5th wheel hitch sits between them, should be enough room. as for holes, depends on how he mounted it. lots of guys just cinch them down with the hooks in the box. me, i drilled holes and bolted it to the floor. and yeh, well worth selling if its not going to work. new tank will run you 600-1000. the pump with hose and nozzel will run another 500 new.
bailey |
It might make heading out the mx track a challenge, I'll have to make sure I have a bed extender. Thanks again for your input. |
When my 2005 4x4 F-450 DRW was being built I asked for the Aux. tank. It provided an additional 19 gals. to the main 40 gal. unit. back then, diesel was the least expensive fuel.
Bear in mind at 8 lbs. a gallon, the curb weight can climb fast. Best of luck and happy miles with whatever tank combo you decide! 73 Jon |
i dont know how much feul you plan on carrying all the time. but i carry 100 leters in my truck full and 400 leters in my tidy tank all the time along with all the other crap i have on my truck. on my 350 drw, it was sagging and sitting on the overloads all the time. i had it weighed and it was sitting at 5800 kg. i then added firestones and it leveled out the ride. dont notice any ride difference except my headlights arent pointing to the sky.
bailey |
7.3 LB's per gal. Doug |
Great info, I appreciate everyone's responses.
![]() If I can keep it, it makes sense. I'll have to make sure it doesn't interfere with the hitch. The previous owner also installed air bags, which is great. He said he just puts diesel in both, and when one gets near empty (the light comes on), he switches to the other one. That makes sense, as it would keep fresh diesel in both, and not let it get old. I'll also keep in mind the weight, that is definitely something to consider. I don't make too many trips where the distance would really warrant the extra tank, but I guess it makes sense to have it in case I do need it. It's also nice to have that in my back pocket, in case I need to bug out for any reason. |
