Do these temps seem normal? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-25-2012, 11:44 AM Thread Starter
75 MPH. ECT 216-220. EOT 218-220. TFT 188-192. EGT 850-1050. IAT 102-104.
This is unloaded pulling rolling hills of east Texas. Don't know ambient but its freaking hot, prolly somewhere around the IAT. Thanks for any input.
Sent from my DROID RAZR using AutoGuide.com App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #2 of 18 Old 06-25-2012, 12:05 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Seems a bit on the high side to me but not extremely so. Running like that here though my trans never gets above 170.
I'd have your fan set to come on earlier if it was me. That can be done in your SCT tunes.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 18 Old 06-25-2012, 03:13 PM
southend's Avatar
Tft seems high, dirty radiator fins maybe?
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #4 of 18 Old 06-25-2012, 03:20 PM
Galaxie's Avatar
Well the good news is, no major deltas. The temp is well over 100 outside.....hum, seems a TAD high but nothing horrible. Are you missing your lower shroud under the front bumper? I had mine off when I was involved in a 10 car pile up (its ok, my truck was the best out of everyone) and when that was off my temps were a good 10* higher than normal but all were still safe...
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 18 Old 06-26-2012, 09:14 AM Thread Starter
Thanks for the input. I think I am going to install a new water pump and a aluminum rad, it has 204K and as far as I know they are original. When I install them I am going to take my intercooler, trans cooler, oil cooler, and condensor out and clean them out real good. I am also considering putting an additional trans cooler under truck right before the fluid goes back into trans.
I installed a 16" electric fan pushing from the front and that didnt really help.
I have a Ranch Hand full bumper and I know that it is limiting air flow, but I didnt think that it would that much.
post #6 of 18 Old 06-26-2012, 04:54 PM
My temps sit around 206-210ect and 212-216 eot while cruisin flat highway. I noticed this is considerably higher than most forum members, and usually the temps up here in Alberta aren't exactly breaking any thermometers. Could it be coolant to water ratio? Overall coolant level?
2005 F350 6.0 CCSB
4" 304 Stainless MBRP Turboback w/ Cat Delete
Edge Insight CTS
Rotella T6 5w-40
Sinister Coolant Filter
325/60R18 Dick Cepek F/C Radial II w/ 2" pucks
Stock EGR Cooler 190000 kms
tonto is offline
post #7 of 18 Old 06-28-2012, 09:03 AM Thread Starter
I read about LilPooh's water pump and I had the exact same thing happen to me. I put a new fan clutch on and it stabilized the temp's but they are higher now than what they were last year. I'm gonna get me a BPD water pump, hold off on new rad, still clean everything and see if that helps. Thanks a lot.
post #8 of 18 Old 06-28-2012, 09:49 PM
i actually had this same issue just repaired today... i was running 215 ect with 221 eot... i concluded that my fan clutch wasnt working correctly, replaced and now my coolant doesnt go over 195*... Hope this helps
element8906 is offline
post #9 of 18 Old 06-29-2012, 10:05 AM
still runs's Avatar
ive noticed mine on hot days 80s and higher i run 192 ect and 198-200 eot i dont like like that but what can you do ??
arp studs and all new gasgets
blue spring.... its really blue
full egr delete
Bts tranny
coolant bypass and fillters
rotella red elc
cummings 5.9l banjo bolts
4 inch turbo back
Custom tunes by spe
2.7 leveling kit
next on the list
new injector$ $$$$$
regulated fuel return
ficm & ecm to php along with my evo to be flashed
and half in my 401k lol
still have my 401k all of it
SYLSOS
still runs is offline
post #10 of 18 Old 06-29-2012, 10:53 AM
RRF985's Avatar
Yesterday while driving I was at 202 ect and 206-210 eot. 95 degrees out. Ran warmer than expected.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
