This forum does not instill confindence!!
Wow. I have been debating on trading in my 06' Mustang GT on a 05' crew cab dually with the diesel. My clueless thought on it (and I cannot be the only one) is that a diesel will run forever. Well after rummaging through this forum, and seeing pictures of everybody's cab hanging over their truck I am becoming a little worried about getting one.
I take it that most of these issues with the diesels are a not "if" it happens, but a "when" it happens kind of deal? What kind of price are we talking for these basic fixes? I will be getting a 4 year extended warranty on the truck too. I am no longer wanting to be wrenching on a vehicle other than basics. With that said, would this truck not be a good idea to get?? Thanks in advance.... |
Fact of the matter is that these trucks are expensive to own and operate. They are prone to oil coolers clogging up which can lead to blown egr coolers and blown head gaskets if not caught early enough. You need a good monitoring system like the Edge Insight or at least a ScangaugeII so you can keep an eye on vitals and fix things before it cascades into a big repair bill as in the scenario above. It is certainly cheaper if you turn your own wrenches. A good cooling system flush, a coolant filter, and proper cooling system maintenance goes a long way for reliability. If you are looking for a buy it, change oil once in a while, and drive it then I suggest you get a gasser. If you're willing to monitor your vehicles systems and be absolutely meticulous in your maintenance (which ain't cheap, $100-$120 oil changes every 5k miles for example) and do so reliability preventive maintenance up front the 6.0 is a great motor and the Super Duty is the best truck out there.
Do the basic checkups before buying another vehicle, oasis, any signs of leaks etc.
I'm a new diesel owner myself. I don't tow or haul anything, but when I bought this truck it was in my mind that I would like to have a slide-in camper or travel trailer someday. The research I had done was before diesel got more expensive than gas, and probably before the 6.0L came out. What I learned then made me lean toward the diesel, but what I've learned since has mostly been against. If I had the same decision to make today I would not choose the diesel, or at least I would wait until I had a real need for it. If I needed a truck, it would be a diesel, in fact it would be THIS diesel, the 6.0L, but I don't really 'need' a truck at this point. Since I have it I'm taking care of it right, and I'm not planning to get rid of it, but that's because I can afford the extra money (so far) and I like working on things. And I do LIKE having a truck, and a diesel, and I LOVE the 6.0L.
You should take what you're learning seriously. Try to learn a lot more before you make a decision. As a buyer today, I would be very hard on the seller. I would use my ScanGauge and find every fault I could, and I'd hold them against the price hard. If they wouldn't make me a great price, I'd pass. Due to a series of bad decisions and uninformed owners and dealers, these trucks should be available for a lot less than they're worth, and I'd hold em to that. Last edited by Idahoser; 06-25-2012 at 09:59 AM. |
Ok, so kind of a hypothetical, say I buy the truck and no leaks everything seems fine. I hook up the monitoring system and everything is fine. Say a year later the oil and coolant temps start verying towards the 15 degree difference mark. Will this be a fortune to fix? Or since I will be catching it early it will be okay?
And when you say flush the coooant, how often do you have to do it?? Sorry for all the questions but it is turning into a much bigger decision! lol And thanks for the help already!! |
And don't listen to that idiot at Powerstrokehelp.com or you'll really be in trouble.
Also, the 2005 I am looking at only has 60,000. Could there be much damage done by this mileage mark?
As for flushing the cooling system it depends on what coolant you decide to run. If you stick with the Ford Gold (G-05) coolant I receommend every year or 30k miles whichever comes first. If you switch to a Cat EC-1 rated ELC coolant meant for diesel trucks the operational life is a minimum 5 years or 300k miles. |
Buy a Cummins..................
The cost of repair to the oil and egr cooler is really up to you with two differnt out comes. The first is you do it right the first time and never have to worry again. This is done by going to BulletProofDiesel - Darn-Near Bullet Proof Diesel Products for your 6.0 and getting their coolers. The price is right around $3100.00 this includes egr cooler, oil cooler, arp studs, head gaskets and and the other gaskets needed (labor not included). The other option is to replace with factory parts and continue to worry when they will fail again. It may be 50,000 miles, it may be never. The price is half of the first option however the choice is yours. I say go for it if you want an awesome truck.
